Problem with missfire in DB9
Old Mar 15, 2012 | 06:27 AM
keisuko's Avatar
keisuko is infamous around these parts
try to change spark plug and ignition coil that still got the feeling of jerking,do anyone here have this kind of problem in this ride before?
try to diagnostic that i get is P0316.
Old Mar 15, 2012 | 09:34 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
You might need to get the misfire corrections learned. Other than that....the timing might be off, which would be a mistery how that happen. The crank sensor might be faulty, or a damaged flywheel.
Old Mar 16, 2012 | 12:28 PM
Irish07@VelocityAP's Avatar
You did all this for P0316? P0316 is misfire on startup..which would be more fuel related..after 1 min at 2,500rpm what fuel pressure do you have on both rails, should be 40psi..also which pcm is flagging this fault..pri or sec?
I also second the misfire corrections idea if there not stored..
kensilver
Sep 17, 2015 04:03 PM
Old phart
Sep 14, 2015 04:47 AM
Ekaplan1020
Sep 12, 2015 08:23 PM
Wildcat1212
Sep 7, 2015 11:31 AM
