Scraped the underside of my front splitter :(
Old Apr 16, 2012 | 07:24 AM
Dr. G's Avatar
Dr. G has a spectacular aura aboutDr. G has a spectacular aura about
This weekend I drove the S to my uncle's home. I went to make a U turn and pulled into his driveway which, unfortunately, had more of an incline than it appeared. I heard the horrible scraping noise and immediately backed up. I didn't crack the cf, but I definitely scraped it up underneath. Is there an easy fix for this? It doesn't look like I compromised the integrity of the cf, only the finish over it.
Old Apr 16, 2012 | 07:51 AM
telum01's Avatar
i'd imagine it's just a matter of reapplying a clear coat. you should be able to find some stuff online (google carbon fiber clear coat or something like that), or a place that can just do it for you, maybe even just a body shop.
edit: i googled "carbon fiber clear coat repair" and plenty of info came up, so it shouldn't be hard to figure out how to do it yourself, and it looks like it'd be cheap and easy for a shop to repair.
Old Apr 16, 2012 | 09:59 PM
DetomasoGTS74's Avatar
Per Telums recommendation, take it to a good body shop you trust. I have seen badly scraped CF (as long as its not in the weave under the clear) made to look brand new. They will sand it, and recoat the clear.
Old Apr 16, 2012 | 10:04 PM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
I hate to say this, but this isn't the only time it will happen. Since its already scraped, you won't cringe so much the next time you do it. As long as its not cracked and only scraped underneath, who's going know? That squirrel you just ran over?
Old Apr 16, 2012 | 10:24 PM
telum01's Avatar
True, nobody can see the underside, but the clear coat is there to protect the carbon fiber weave itself. If the scraped-off clear coat isn't repaired, the carbon fiber will be less protected and will eventually be damaged from a scrape.
Old Apr 17, 2012 | 12:38 PM
Dr. G's Avatar
Luckily I had some venture shield over it as well, so I didn't do as much damage as I first thought (although I still got into the clear a bit). I may just replace the wrap on it.
Enemy
Nov 10, 2015 08:01 AM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
