New key stuck in the ignition.
Old Apr 16, 2012 | 02:15 PM
ewu64's Avatar
ewu64 is infamous around these parts
I received a second key by mail from Aston Martin. The key opened the doors fine but when I went to start the car, the start button didn't light up red. I pressed it anyway and it didn't start. Now the key doesn't want to come out of the ignition. What to do?
Old Apr 16, 2012 | 03:56 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
I suppose you have tried to move the steering wheel back and forth to relieve any tension on the key?
Old Apr 16, 2012 | 05:06 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Old Apr 16, 2012 | 06:21 PM
ewu64's Avatar
Originally Posted by spinecho
I don't have a glass key. I have a regular key that goes in the steering wheel. I have tried turning the wheel to realese the lock, nothing. And I forgot to mention, on the info screen in the tach, it says " key error "...
Old Apr 16, 2012 | 11:15 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
The ker error fault is due to it not being programmed. I have had a few new keys get stuck, and it takes so force to get it out.
Old Apr 17, 2012 | 04:51 AM
ewu64's Avatar
AMfixer, I haven't pull the key with a lot of force of fear of taking the drum off the steering altogether! Should I apply a lot of force without fear of taking the ignition drum with me?
Old Apr 17, 2012 | 09:29 AM
AMFixer's Avatar
Can you still turn the key? Does the key turn all the way back? Anyway to spray some wd40 in the barrell?
Old Apr 17, 2012 | 10:36 AM
ewu64's Avatar
The key turns freely from position 0 to position 2, without any issues. It just does not come out !!! That was going to be my next question! Can I spray WD40 in the barrel to see if the comes out? Will the WD40 screw up any electronics inside the barrel?
Old Apr 17, 2012 | 11:29 AM
AMFixer's Avatar
Yes you can, just dont unload a whole can into the barrell.
Old Apr 17, 2012 | 02:19 PM
ewu64's Avatar
What about two cans? :-))
Thanks, AMfixer. I'll let you know if it worked later!
Old Apr 17, 2012 | 07:34 PM
ewu64's Avatar
Key is out !!! Thank you AMfixer..
I injected Liquid Wrench Penetrating Oil around the key, into the tumbler. Then, from the passenger side, I lodged my knees against the center console, and pulled the key with both hands. The key came out in two stages, first half, and on a second pull, all of it. One funny thing about this ordeal,... that last pull, made me fell backwards, out the passenger door !!!
"Idiot killed himself while trying to pull key off his car"
Bmw M3 Guy
Feb 21, 2018 09:29 AM
Stormdog
Sep 26, 2015 03:18 PM
allroadusa
Sep 25, 2015 10:57 PM
kensilver
Sep 17, 2015 04:03 PM
lokmeup
Sep 9, 2015 09:24 PM
