What is the best way to lower my 2010 DBS?
Old Aug 25, 2012 | 05:45 PM
MichaelD's Avatar
MichaelD is infamous around these parts
The sports suspension doesn't drop the car, the ride height is exactly the same with sports or normal suspension.
Old Aug 25, 2012 | 06:08 PM
LRDog's Avatar
LRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond repute
Pretty sure the sport pack, at least on the DB9 does drop the car a nominal amount but I do not recall how much. Not sure about the Vantage.......
Old Aug 25, 2012 | 08:55 PM
sunir's Avatar
^^^ agree w LR, on DB9 I know the sport pack drops the car w sport springs... Which couple w the more aggressive sport dampers...
Old Aug 25, 2012 | 10:08 PM
DetomasoGTS74's Avatar
Its the same for the Vantage....so do you know the drop?
Old Aug 26, 2012 | 06:06 AM
MichaelD's Avatar
If you check the manual for the vantage, you'll see that there is no height difference with the sports suspension, which confirms the view I had from the dealer. If you see two cars side by side, one with sports and one with standard, you will see that they are at the same height.
There are aftermarket tuners that offer lower suspension, maybe that is the package you're thinking about?
Old Aug 26, 2012 | 06:35 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
SP does not lower the Vantage but it does on the DB9
AM have done a great setting up the different suspension package
If it ain't broke don't fix it!
Old Aug 26, 2012 | 08:47 AM
You guys are right, from what I could dig up the SP lowers the DB9 6mm and the V12V essentially has the sports pack suspension with a 15mm drop. I agree that it is a great set up mikey!
Old Aug 28, 2012 | 04:32 AM
1JDM911's Avatar
1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of1JDM911 has much to be proud of
Originally Posted by plastique999
Oh forgot as a side note, I would not do springs on the DBS as I'm sure it would effect the adaptive suspension system on the car.
d0h!
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
FUTURESTAR
Sep 23, 2015 05:42 PM
TitanMotorsport
Nissan GTR
Sep 23, 2015 03:25 PM
jpik2003
Sep 10, 2015 05:18 PM
