Headlight Washers Stuck
Old Oct 9, 2012 | 07:53 AM
vonFerro's Avatar
vonFerro is infamous around these parts
Hey folks,
Both my headlight washers are no longer functioning. They spray liquid inside the compartment which leaks out, or on occasion come out maybe an inch.
Checked in with an Aston UK dealer whom I was getting quotes from (148 pounds per nozzle, pump, cover assembly) who indicated this is a common problem and flushing the system with fresh water should resolve the issue.
If it does, it will save me some good coin.
Has anyone experienced this? Unsure if the flush needs to be done at a shop, or if they actually mean sitting there with water and continually running the sprayers hoping the water clears it.
Thanks!
Old Jan 2, 2017 | 02:02 PM
Organeer's Avatar
Organeer is infamous around these parts
Hi, I've just seen this post and realised it is quite old but I am having a headlight washer problem as well.
Did a flush of the nozzles work?
How did you access the washers to flush them?
mmdht2
Cayenne 958
Mar 29, 2016 12:33 PM
Josh/AWE
991 Vendor Classifieds
Oct 16, 2015 03:31 PM
sechsgang
Sep 18, 2015 09:27 AM
