6-Cyl DB7 Running Warm?
Hello,
I've owned my '97 DB7 with the SC six for a year now, and enjoy it a lot (except that, truth be told, it could use a bit more "oomph"). I only have one issue-- when warmed up, it seems to run a bit too hot. The temp gauge reads at the 1 o'clock position, one notch past straight up. It gets hot faster when I climb a hill, but the temp drops quickly when I go down a hill. The car seems to run fine regardless. Is this "normal" for this model/engine? Or is a radiator overhaul in order?
TIA for any comments.
I work on a few I6 SC'd DB7's, sounds really normal to me. Even with the intercooler, the SC gets the temp up there and fast. Guess thats why Aston went to the DB7 Vantage (aka..V12) ..hehe then again Dr Bez is against forced induction..but thats other topic
If the mileage on the engine isnt high at all, don't think the rad would need a re-build. But what you can do is service the cooling system if this has not been done. The cooling system (per Aston) is to be serviced(coolant replaced) every 2 years or 30,000mls, which ever comes first. When replacing the coolant, if you have no idea about the thermostat, as in when it was last repalced, also replace the thermostat and add in a bottle of Water Wetter to the coolant when mixing. The Water Wetter will help bring done the coolant overall temp a few degrees.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
