"Emission Service Required"
Old Jan 4, 2013 | 10:37 PM
gircal's Avatar
gircal is infamous around these parts
This alert just popped up on the screen on my 2012 Rapide (5K miles on it).
Does anyone know what it means or what in the "emission system" can be
serviced? Thank you.
Old Jan 4, 2013 | 11:02 PM
groutguy's Avatar
groutguy has a spectacular aura aboutgroutguy has a spectacular aura aboutgroutguy has a spectacular aura about
your rapide is too new to guess on the usual culprits, such as the cats. Other than checking to see that your gas cap is tightened on properly, your best bet is the dealer. A diagnostic scanner would be the easiest way to figure the problem out. Whatever is causing the issue would still be covered on the standard three year warranty.
Old Jan 5, 2013 | 07:46 AM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
This is a common problem with our cars. Mine has only flashed it once and when I checked it with my code reader everything was within spec. All I did was erase the code and it hasn't come back yet (been almost 6 months). Definitely get a code scanner and see what your code is. A good scanner should be able to test the emission system components in real time to make sure things are working. The port for the scanner plug in is right under the steering wheel.
Old Jan 5, 2013 | 08:00 AM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
That message comes on for the weirdest of things! I had my rear bumper cover removed for painting, once it was refitted the Emissions Service light came on....Grrrrrr.
When, I took it to the dealer the on board computer had logged an error code to do with the rear bumper removal. The dealer reset and all was good.
Anyway, I suppose the moral of the story is get the dealer to check it as it'll probably be nothing of serious consequence, and he should be able to check it while you wait.......as Grout mentioned above; I would probably check that your gas cap is on correctly first though!
FF
Old Jan 5, 2013 | 10:08 AM
plastique999's Avatar
plastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to all
Common issue with our cars.
Get an OBD scanner - I have had the P2195 code which has to do with the O2 sensor. Just clear it and fine
Old Jan 5, 2013 | 10:17 AM
gircal's Avatar
Many thanks for all of your comments. Any suggestions as to which OBD scanner to buy and where ... online?
Old Jan 5, 2013 | 10:59 AM
sunir's Avatar
Although I've not yet seen this on my DB9, I've heard the common culprit is fuel filler cap. As others have mentioned check that first make sure it's properly fitted after fueling.
Old Jan 5, 2013 | 11:16 AM
dan87951's Avatar
This is my scanner which works well on Porsches and my Aston Martin.
Equus 3140 Innova Diagnostic Code Scanner
Old Jan 5, 2013 | 11:36 AM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
I have this scanner that works well on all my vehicles. Clears codes with a few button pushes:
Amazon Amazon
Old Jan 5, 2013 | 07:24 PM
DoubleLow7's Avatar
DoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of light
+1 on the gas cap. When I had that message popped up, the gas cap wasn't sealing correctly. Replaced by AM under warranty which you should be able to if it's an issue.
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
