Yet another project for my Vantage
Old Jan 17, 2013 | 01:31 PM
sonnyd's Avatar
sonnyd is a jewel in the roughsonnyd is a jewel in the roughsonnyd is a jewel in the rough
Karl-Franz, thank you very much!
Since you've been into both the stereo and the steering wheel, is it possible to plug-n-play the stereo volume switchpack onto the steering wheel for those cars that don't have it?
Old Jan 20, 2013 | 06:02 PM
telum01's Avatar
seriously awesome write-up for the steering wheel. that's just fantastic.
earlier today i was thinking about how badly i wanted to wrap my steering wheel in alcantara for feel and a touch more thickness and padding.
awesome stuff, thanks for posting it!
Old Jan 20, 2013 | 07:22 PM
sunir's Avatar
Wow Karl ! Awesome work again! You are an inspiration in diy projects, thank you for sharing your incredible craft and creativity with the rest of us.
Old Jan 21, 2013 | 05:30 PM
karlfranz's Avatar
Unfortunately, there is no easy answer to this. It depends on the car MY and what options it has. In older cars, the left switchpack was for the phone and interfaces to the bluetooth module. Only newer cars with the newer style switchpack can control the stereo volume and the next/prev CD track or FM preset.
For me, I sourced a wheel with both controls because I wanted cruise control for my car, but I also thought that having both switchpacks adds a certain symmetry that is lacking when the steering wheel has only one set of controls. Of course, reaching to the center console to select the stereo is only an arm's reach away, so no big loss. The wheel also looks good at night since both switchpacks light up.
Old Mar 21, 2013 | 11:32 AM
V12Vin's Avatar
V12Vin
Karl,
Found your post via search. Very impressed with your work. Picked up a 07 AMV8 recently and planning to retrofit the CC switch, yeah for symmetry really.
Couple of questions if you don't mind.
1. Battery disconnect. I am aware of the disconnect switch in the trunk but the manual mentioned about disconnecting the switch within 10s of the car shutting down to prevent the alarm from sounding off. So I have to start the car, shut down, rush to the trunk and activate the switch? As easy as that? Any tips?
2. There is this junction box(has a label like DA K57) where both switch packs go to. That rectangular box north of the steering wheel. Is there just a junction box or is there circuitry in there? Cos on the circuit diagram, the wires from CC switch pack seems to go directly to the slip ring.
3. Did you get your dealer to activate the CC switch pack?
Thank you for your time.
V.
Old Mar 21, 2013 | 01:34 PM
SpeedwareMotorsports's Avatar
SpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to behold
Amazing work - I always wondered how they stitched the steering wheels. Might have to try this myself sometime.
Old Mar 21, 2013 | 02:15 PM
FluidMotorUnion's Avatar
FluidMotorUnion has a spectacular aura aboutFluidMotorUnion has a spectacular aura about
Awesome work, definitely a nice touch !
Old Mar 21, 2013 | 02:19 PM
MishaDesigns's Avatar
Love the attention to detail. Great job
Old Mar 21, 2013 | 03:49 PM
karlfranz's Avatar
Originally Posted by V8Vin
Karl,
V.
Greetings. Here are my replies:
1. Or you could, you know, actually disconnect the battery. ;-)
2. Don't know the innards of the box you describe as it is sealed. My guess is that there is some circuitry to multiplex all the signals together on the limited number of pins of the connector. It shouldn't matter, though. It is plug and play to swap from the non-cruise harness to the one with it.
3. Yes. The dealer uses AMDS to reconfigure the ECU and indicate that the car has cruise control. Since the Aston uses throttle-by-wire, the electronics and software are already present and capable of doing a cruise control function. All that is needed are the actual controls and to notify the ECU they are present.
Cheers.
Old Mar 21, 2013 | 05:43 PM
V12Vin's Avatar
V12Vin
Cheers.
Karl,
Much appreciated. I don't see the harness listed in the EPC as well which would have made this upgrade easier.
Will hunt on eBay for a used wheel.
Also great job on the Dension project!
V.
Old Mar 21, 2013 | 07:15 PM
karlfranz's Avatar
I don't believe Aston sells the wiring inside the steering wheel as a separate line item, sorry.
Old Mar 22, 2013 | 03:08 AM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
Wow! Really awesome. You may soon have a burgeoning side business!
Old Mar 22, 2013 | 05:45 AM
karlfranz's Avatar
^^^^ Thanks, but I think I'll stick to my day job.
Old Mar 22, 2013 | 09:30 PM
M Kube's Avatar
M Kube is infamous around these parts
Awesome and unique look.... I like it!
Old Jul 7, 2013 | 03:03 AM
karlfranz's Avatar
So in keeping with my goal to continually teach myself new skills, I decided to learn how to do vinyl wraps and experimented on my V8V. I know this won't be to everyone's liking, but keep in mind it is temporary and I can remove it without damage at any point. The vinyl I used is the 3M 1080 Scotchprint in brushed blue steel (Insert Zoolander joke here). I'll probably keep it for a few months and then switch to something else. I'm thinking a black matte or satin roof might be next.
Oh, and thanks to Dave (Racer_X) for the inspiration. See his thread here:
https://www.6speedonline.com/forums/...omplete-4.html
Here's the result
