V8V aftermarket exhaust switch
Old Jan 31, 2013 | 04:06 PM
sonnyd's Avatar
sonnyd is a jewel in the roughsonnyd is a jewel in the roughsonnyd is a jewel in the rough
With the installation of RSC 200 cell catalysts (highly recommended), I'll be installing an exhaust bypass switch, allowing me to get out of the neighborhood with the exhaust valves closed. Some of you have already installed switches to create either a N.O./N.C. condition, so I'm looking for some advice.
What kind of switch would you recommend, and where would you recommend installing it? I'd love to have a pushbutton style to the left of the starter button, but messing up the bite-the-back-of-your-hand beauty of the Vantage interior makes that a nonstarter. I'm looking for something easily accessible on the fly, but sufficiently tucked away for the sake of discretion.
Bonus points for low quality photos.
Old Jan 31, 2013 | 07:15 PM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
I mounted a switch that fit right where the cigarette lighter would sit in the ashtray. I just open the lid and press when necessary. I wired the switch to ground and when selected it provide ground to a relay in the boot which when grounded provides power to fuse 22. When switch is the other position ground is not provided therefore no power to fuse 22 and the exhaust is loud. By using ground there is no power being brought to switch and no risk of a short. Cost was about $15 for relay, switch and relay plug
Old Feb 1, 2013 | 06:34 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
You don't need to modify your interior. You can get a wireless remote switch that is operated by a small fob that you can keep in the drink holder of the car. See the thread below:
https://www.6speedonline.com/forums/...te-switch.html
Old Feb 1, 2013 | 08:56 AM
karlfranz's Avatar
^^^^ or program one of the Homelink buttons on you mirror.
Old Feb 1, 2013 | 09:32 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Here's what I bought and installed and it's all you need. The switch module gets installed back by the little fuse box on the right side of the boot. You should install little spade lugs (radio shack) on the two wires that plug in to replace the fuse. Then one wire goes to +12V and the Black wire goes to ground. As KarlFranz mentioned, you can program two buttons on your home link (as I did) to operate the Relay.
Amazon Amazon
PenguiN
Apr 22, 2021 07:33 PM
Sep 14, 2015 06:42 PM
Ferrari
Aug 24, 2015 04:35 PM
HolmaN
Aug 18, 2015 01:35 PM
