2012 V8V fuse 15 or 22 ?
Old Feb 15, 2013 | 07:12 AM
AST_X's Avatar
AST_X is infamous around these parts
Question 2012 V8V fuse 15 or 22 ?
Hi guys! im about to pull out my fuse, but i have be searching around and im confused for 2012 V8V should i pull out the fuse 15 or 22 ?
Old Feb 15, 2013 | 07:17 AM
DaveHutchinson's Avatar
DaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond repute
15 on MY11 onwards
Old Feb 24, 2013 | 03:28 PM
wem's Avatar
wem
wem is a jewel in the roughwem is a jewel in the roughwem is a jewel in the rough
In my MY 12 V8VS, fuse 22 is a 20amp fuse, fuse 15 is a 5 amp fuse. The owner's manual says the exhaust bypass is fuse 22. Can someone confirm whether the fuse to pull is a 20A or 5A fuse?
Fyi, I didn't notice a big difference when I pulled fuse 22 (or fuse 15). Maybe the sport exhaust on the S makes the difference less apparent?
Old Feb 24, 2013 | 03:45 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
I'm not sure which year but they changed the fuse so it can't be pulled any more. The fuse now controls more than the bypass valves. I could be wrong about this or thinking about a different car.
Old Feb 24, 2013 | 04:04 PM
MY11 onwards should be fuse 15 and I believe this applies to the V8VS too. You are correct, fuse 15 is a 5A but it does the same job as the 20A used to in the old 22 position. It made almost no difference to mine until I actually got the car under load, notable improvement below 4k rpm.
Old Feb 24, 2013 | 07:53 PM
timwhayden's Avatar
timwhayden is infamous around these parts
Karl-Franz says that the valve is always open anyway at start up and idle and so pulling the fuse doesn't make any difference there until you get the rev's up past idle some when the valve would normally close. I have never heard anything about 22 or 15 having anything else on that circuit though.
Old Jun 21, 2013 | 05:56 PM
aaron01845's Avatar
aaron01845 is infamous around these parts
I have a 2013 Vantage V8 and removing fuse 15 did the trick. It's like night and day.
Old Jun 21, 2013 | 06:14 PM
lacir's Avatar
lacir is infamous around these parts
2011 N420 (has sport exhaust). Fuse 15 even though the manual says 22. Essentially drive it through the rev range and see if theres a noticeable change at 3k (the n420 opens at 3k). If there is a difference instead of a linear increase in noise then the valve is closing/opening. Pulling fuse 15 leaves it always open for me.
Old Jun 21, 2013 | 06:51 PM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
How about for a 2007 V8V? Since it is an earlier model is it the 22 then?
Old Jun 21, 2013 | 07:11 PM
LRDog's Avatar
LRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond repute
^^ or, you could just disconnect the vacuum lines on either side of the resonator? I've done it to both. My AMs.....
Old Jun 21, 2013 | 08:03 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Nope they simply moved it to 15 around about MY12
There has never been anything but the vac pump on 22 or 15
Old Jun 22, 2013 | 03:04 AM
Grant3's Avatar
Grant3 is just really niceGrant3 is just really niceGrant3 is just really niceGrant3 is just really nice
+1 it changed on the Vantage for the 11MY, the manual still states ( boot ) fuse 22 but it is in fact now 15.... Presumably they changed it in an attempt to stop us all pulling the fuse
Old Dec 5, 2013 | 09:07 PM
mantonkroh's Avatar
mantonkroh is infamous around these parts
Hi there! I saw your post on the exhaust valve. I just got a 2013 Vantage V8. I'm about to pull the Fuse 15. I saw the fuse 15 (25A) was for the Starter motor solenoid. Is this the one? I'm nervous that I will F up the car.
Thanks in advance for your help!
Manton
Old Dec 6, 2013 | 02:09 AM
mikey k's Avatar
No its the one in the boot
Old Dec 6, 2013 | 02:19 AM
mantonkroh's Avatar
Thanks Mikey. But there is no fuse 15 in the 2013. It's indicated as "not available" and I looked and there is nothing there.
