2005 DB9 or 2007 Vantage
Old Mar 3, 2013 | 06:26 PM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
OK guys, i have asked several questions about these cars and this will be one of my last. These 2 cars are priced similar, is one better than other for reliability?
I ask cause if i am not mistaken the DB9 was built under different AM ownership than this year Vantage. also, the Vantage has the "sport package" upgrade
Thoughts?
Old Mar 3, 2013 | 07:21 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
I prefer the look and driver feel of the DB9. The experience with the V12 is breath taking. Again this is all subjective and the best thing to do is drive them both and make your own opinion.
Old Mar 3, 2013 | 07:30 PM
Christian's Avatar
^i am more concerned about the reliability of these model years to each other
Old Mar 3, 2013 | 07:35 PM
dan87951's Avatar
You can't go wrong with either. Mine has been dead reliably so far. Common issues I know on the DB9 are: Linn Stereo amplifiers will die, NAV gears break (easy fix $15), and transmission cooling line will seep (updated kit). Other than those issues the DB9 has proven to be really reliable. This has been beat to death on the forum and a search will prove both cars are reliable. Shoot.. there is one on Autotrader with almost 90k miles for sale. I think this speaks volumes about reliability.
Old Mar 3, 2013 | 07:37 PM
Christian's Avatar
^thanks, this is the feed back i am looking for
is your car a auto or manny
Old Mar 3, 2013 | 07:40 PM
dan87951's Avatar
Automatic, I did not want to deal with the expense of clutches. The auto transmission is exactly that full auto with no computer controlled clutch plate like in Lambo's E-gear. In other words there are not clutches to change on the automatic in this car unlike Lambo's auto transmission (e-gear).
Old Mar 3, 2013 | 07:42 PM
Christian's Avatar
does the db9 shift smooth and fast? its a paddle behind the wheel correct?
Old Mar 3, 2013 | 08:31 PM
sunir's Avatar
DB auto gearbox is a tough ZF unit and uses a torque converter like any other auto box. My DB is a manual gearbox (graziano rear mounted transaxle same as Ferrari and other exotics) with sport pack, it's much more sports oriented and tight on the twisties but it's harsher on the road you feel more than the non sport pack, I think it adds a new dimension to the grand touring. The vantage is more sportster, the v12 option in any Aston is desirable but the v8 is great also. Both DB and vantage are dead nuts reliable, and in the exotic car world that says spades. Drive both, if your a porsche 911 guy you may like the vantage right off the bat.
Old Mar 3, 2013 | 11:29 PM
Speedraser's Avatar
Speedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond repute
Generally, the cars got better over the years, so it's likely that an '07 will be better-built and more reliable than an '05, whether it's a V8 or a V12. That said, the DB9s and the V8Vs are generally reliable. A V8V, especially with the Sports Pack (which must have been retrofitted since it wasn't available in '07), will be a much sportier drive than an '05 DB9, which is much more of a GT. Through the gears, the performance will be nearly the same, but the V12 has massive torque, while the 4.3 V8 needs to be revved to extract its performance.
Old Mar 4, 2013 | 12:11 PM
mikes300's Avatar
mikes300 is infamous around these parts
Very smooth! and yes and yes, would be my answers.
Old Mar 4, 2013 | 12:40 PM
sunir's Avatar
Mike is just being modest...honestly it feels like, well, remember in Star Trak when they hit warp speed, and everything outside becomes a blur of bright streaking lights...well sorta like that!
Old Mar 4, 2013 | 03:13 PM
XJRS Owner's Avatar
There is nothing wrong with an early DB9, but I think you'll find that the steering on the later DB9s is a significant improvement, providing more road feel and response, and eliminating the artificial heaviness that exists in the middle of a turn.
This heavy steering was a relatively common complaint with road testers, but was something that Bez preferred so that's the way the steering was designed. When the DBS came out in early 2008, the steering effort was greatly reduced so that it is much more linear throughout the range. This improved steering was fitted to DB9s also.
adnanm3
Nov 22, 2023 02:43 AM
pshep138
Oct 6, 2015 11:58 AM
Ekaplan1020
Sep 12, 2015 08:23 PM
midtownlandman
Sep 3, 2015 01:17 PM
