Coolant level low message. Help
Old Mar 24, 2013 | 08:41 PM
tko211's Avatar
tko211 is a jewel in the roughtko211 is a jewel in the roughtko211 is a jewel in the rough
Anyone ever have a coolant level low message come on and off regularly? I've had my 2006 Vantage for a week now and it seems to pop up every so often each time I drive it. I had my mechanic (not aston dealer) check out the coolant level and he said it was full? Is it a faulty code? something else? It comes on for only a second then shuts itself off by itself. Any advise would be helpful. My nearest dealer is Las Vegas apparently.
Old Mar 24, 2013 | 09:54 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Not much mystery in low coolant. Check your tank and fill if needed. Watch for leaks.
Old Mar 25, 2013 | 12:24 AM
tko211's Avatar
No leaks of any kind. The tank reads full, but I still get the code on and off every time I dive it. I'm curious if this has happened to anyone else? Is it related to something else? faulty sensor? I guess thats my question.
Old Mar 25, 2013 | 08:39 PM
drcollie's Avatar
Have you popped the hood and removed the reservoir cap (its black, up near the hood strut on the driver's side) and actually looked in there to see if there is fluid in the tank? You have to press down on the cap to remove it and re-install.
Old Mar 26, 2013 | 07:43 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
IIRC some one on here or Piston Heads had this late last year and it was traced to a faulty sensor.
Old Mar 26, 2013 | 09:46 AM
tko211's Avatar
Thanks! I'm suspecting that might be my issue... Helps to know that there is someone else out there who has had this happen before. I'll have to get it checked out properly.
Old Mar 26, 2013 | 01:22 PM
Irish07@VelocityAP's Avatar
Float usually sticks in the bottle..or I've had the sensor cracked...You can get the switch but it's really a 50/50 cause you can't get inside the bottle at the time of the fault and confirm the float is still free..so everytime I get an older vehicle I replace the resevoir complete which comes with a sensor, and also do a flush if not done recently..gummed coolant is what causes the float to stick..aka 2 birds 1 stone
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Rguy
Apr 12, 2020 11:11 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Rockinc1
Sep 30, 2015 06:44 PM
