AM V8V Transaxle oil change
Old Aug 9, 2013 | 03:02 PM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
4G432710245 - Seal, Flat 22x28x1.5
4G432710491 - O Ring, 2.62x20.63
You should be able to get them from a Ford or Jaguar shop or even your local car parts shop.
Old Aug 9, 2013 | 11:23 PM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
In warming up the rear end after the first fill and before double checking the level for the second top up, I just disabled the traction control and went through the gears while the car was on all four jack stands.
She was just fine until I got her into 6th gear! Then my ABS and and yellow triangle light came on. Now they stay on.
Is there anyway I can reset them, or do I have to go to the dealer?
Old Aug 10, 2013 | 12:19 AM
Vergis's Avatar
Get one of these
http://www.ebay.co.uk/itm/3209113694...84.m1439.l2649
Make sure they are not the reader but the scanner that can delete codes.
Old Aug 10, 2013 | 05:44 AM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
Not sure why you would run car on jack stands, but ABS and traction control works by looking at the differential of speed between wheels. The ECU thinks your wheel sensors have failed. Not sure if the will clear over time or the failure codes need to be cleared.
Old Aug 10, 2013 | 09:10 AM
Vergis, thank you.
millsjq, too much hassle to take the car on an off jack stands. I figured if I take the traction control off then the ECU would let me off the hook in regards to front to rear wheels speeds. I guess not in 6th gear.
Old Aug 10, 2013 | 09:40 AM
millsjq's Avatar
Don't think there is a need to run and recheck level. I have never seen that requirement on any other car, but will check the Aston shop manual.
Old Aug 10, 2013 | 11:55 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Transaxle filter O-ring 4G43-27-10491
Transaxle drain/fill washers 4G43-27-10245 (2 each)
Cole European in Walnut Creek has the Castro Manual BOT 270A at $70/bottle.
Thanks for the current information!
Cole also stocks the 10W-60 Castrol Edge Sport; last time I bought it was $11 and change for a liter bottle.
Old Aug 10, 2013 | 10:22 PM
Took her out for a spirited Saturday night drive. The ABS and yellow triangle light went out on their own.
I guess she needed a good spanking.
alwaysbored786
Apr 19, 2016 05:51 AM
4ocious
Sep 1, 2015 06:44 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
