Brake pads on '13 V8V same as V8S? Porterfield,Carbotech say they have none to fit.
Old Dec 7, 2013 | 04:43 PM
wem's Avatar
wem
wem is a jewel in the roughwem is a jewel in the roughwem is a jewel in the rough
Originally Posted by Fubar
Carbotech has the template now. Call them and speak with Daniel. Wheel dust is dramatically reduced (minor preformance trade off) and no squeaking, yet. I only have about 1000 miles on these.
- call and speak to Daniel. They are not great about returning emails.
I spoke with Mike Jr. 2 weeks ago. He said I was the third V8VS owner he spoke with during the past week. He told me that the V8VS pads are the same as the non S pads based on measurements he had from another S owner. Maybe I need to speak with Daniel based on what you and 007 have said. The brake squeal from the original pads is the only blemish I have with the car. The dealer and I have tried everything mentioned in other threads. During the summer it was tolerable, but once the outside temperature dropped below 60 the noise made the car undriveable.
Old Dec 7, 2013 | 07:54 PM
timwhayden's Avatar
timwhayden is infamous around these parts
Not true. The front pads on the V8VS (and '13 MY non S on) are larger than the non S but the rears are the same. I just got a set of GiroDisc Magicpads I am about to install because of dusting instead of squealing in my '13.
Old Dec 8, 2013 | 11:24 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
The fronts are larger, just tell him S rotors are 380mm, and stock rotors are 355 rotors. That should explain it all... If you need and help/support I can talk to him for you. I will be getting 1521pads if I get any brake squeal (and once I upgrade to 2 piece brake rotors
Old Dec 9, 2013 | 09:15 AM
Fubar's Avatar
Fubar has a spectacular aura aboutFubar has a spectacular aura about
I got carbotech all the way around on my '12 V8V-S, squeal is gone and dusting is significantly reduced. Pad bite is less than the stock set (you can't have it all) but its a sacrifice I'm willing to endure for the quite ride.
Old Dec 9, 2013 | 09:38 AM
Great to hear both noise and dust are gone. Although I felt like mine were biting better than stock after I bedded them in. It did take at least 2-3 weeks of use to really bed them in fully. How did you bed them in exactly? What was your procedure?
Old Jul 31, 2014 | 05:17 PM
brisvegas's Avatar
brisvegas is infamous around these parts
Angry Updates on Pads for V8S
Hi Guys,
I'm new to 6speedonline. I have a 2012 Vantage V8S and are pretty pissed of with the constant brake squeal from the factory pads. (yes I drive hard occasionally and it improves for a day or so).
Any feedback on how the Carbotech or other aftermarket pads have been performing noise and performance wise. I'm really keen to replace current pads with anything that doesn't squeal. Have been considering using the anchor of my boat if things don't improve.
Thanks.
Old Aug 1, 2014 | 07:23 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
I'm on my 2nd V8 and have now done 16k miles in my S
Both squealed like pigs even after the dealers "sorted" the problem
It was recently in at Bamford Rose they did the following and it has sorted the issue!
1) chamfer the edge of the pads
2) install them with some copper slip on the back of the anti squeal shims
3) bed them in properly
I did find when they used to be bad a good pressure wash of the brake would sort it for a few months.
Old Aug 1, 2014 | 08:09 AM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Originally Posted by brisvegas
Hi Guys,
Thanks.
Carbotech 1521 no noise almost no dust
I have on my db9 drove about 5k miles since
Could not be happier.
Old Aug 2, 2014 | 09:50 PM
Fubar's Avatar
Agreed the carbotech pads eliminated brake squeal. 20k miles on the carbotech and not one squeak.
Old Aug 3, 2014 | 06:06 AM
Any ideal how many miles carbo tech lasts?
XLR82XS
Oct 5, 2015 07:02 AM
Rockinc1
Sep 30, 2015 06:44 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
