Brake pads on '13 V8V same as V8S? Porterfield,Carbotech say they have none to fit.
Subscribe
Aug 22, 2013 | 10:34 PM
I can't tolerate the brake dust any longer on my white car. Can I tell them to cross reference the S if they have the pattern for that? I know the fronts are the S brakes but are the rears the same as the pre '12.25?
Reply
Aug 22, 2013 | 10:58 PM
Yes you can. You can also send them a template of the brake pad you want (in 1:1 scale) or better yet an old worn pad and they can custom make a new set if one doesn't already exist. You will also need to supply them with the pad material thickness of a new pad in millimeters. I actually worked with Porterfield to develop the application if the pads for the Brembo brakes on the Esprit. This is why I then went back to them when I first bought my Vantage to get a set made for that car. Now everybody is using them. Give Porterfield a call and talk to them directly about your needs.
Reply
Aug 23, 2013 | 01:37 AM
Had Carbotech make me custom 1521 compound pads (their street compound). It was fantastic, almost no dust, zero noise, great cold bite. It's not meant for track, but anything less than 10 stops in arrow and its awesome. For street it is by far the best pad.
Reply
Aug 23, 2013 | 05:50 AM
Quote: …For street it is by far the best pad I have used.
Fixed that for you.
Reply
Sep 13, 2013 | 04:48 AM
I just sent CarboTec the '12 V8V-S pads so that they could make replacement offerings. They should be ready within the week.
Reply
Sep 13, 2013 | 02:19 PM
to buy Carbotech, which buy Carbotech standard specifications, much cheaper, or Carbotech Bobcat1521, more expensive ??
Reply
Sep 13, 2013 | 02:43 PM
I'm not sure exactly what you mean but Carbotech is laser scanning the pad plate so they can produce any friction compound you would prefer. I am not personally recommending either as I have no prior experience with them. I have never had problems finding aftermarket pads so this is the first time I have needed to have them fabricated. Aston Martin has employed a somewhat unique design that Brembo has not offered to the general public.
Reply
Sep 13, 2013 | 09:06 PM
Fubar, please get them to keep the specs on the the V8VS pads they are making for you so others can get them later without having to send more pads. When I spoke with them they said they had no way to keep the specs since I knew they had made pads for other AML owners previously. That just doesn't sound right to me...
Reply
Sep 14, 2013 | 06:47 AM
I assumed they would do that as standard business practice but I will make sure they know that I am not trying to keep any secrets. I have been dealing with Danny. He just received the pads on Thursday so I doubt the laser scan file is in their computer yet.
Reply
Nov 7, 2013 | 03:10 AM
Any news on this and what are the part nos for fronts & rears?
Reply
Nov 7, 2013 | 08:22 PM
Quote: I assumed they would do that as standard business practice but I will make sure they know that I am not trying to keep any secrets. I have been dealing with Danny. He just received the pads on Thursday so I doubt the laser scan file is in their computer yet.
Fubar, do you know if they kept the file for your V8V S pads? I sent them an email inquiring about the availability of pads (the 1521) for my '12 V8VS, but did not get a reply. It will be a hassle to send in the OEM pads from my car, so I was hoping they had a scan on file.
Reply
Nov 7, 2013 | 09:41 PM
The S pads are much larger since they are on a 380mm rotor vs the stock 355 rotors, that's why they need to have a. New set scanned in. I already had my set sent in years ago and as a result has the first aston set made in 1521. The rears are the same on Vantage S so you can still get a set of rear pads in 1521 compound as they already have the file on hand from when I had my custom set made.
That does not seem out of the ordinary as nobody has probably ever had a front set made before. Seems like standard operating procedure to me.
Reply
Nov 8, 2013 | 09:49 PM
Carbotech has the template now. Call them and speak with Daniel. Wheel dust is dramatically reduced (minor preformance trade off) and no squeaking, yet. I only have about 1000 miles on these.
- call and speak to Daniel. They are not great about returning emails.
Reply
Nov 9, 2013 | 01:33 AM
Bed the pads in more and the performance will increase, it takes time for them to bed in because their wear properties are so good (thereby extending the break in period compared to other pads)
Reply
Nov 9, 2013 | 09:15 PM
Brake pads were bedded, trust me.
Reply
