Fuse 22 Switch Install
Old Sep 4, 2013 | 12:57 AM
DavidSD's Avatar
DavidSD is infamous around these parts
I know there have been lots of posts already on Fuse 22, but having foundsome tremendous information on this forum I thought I'd return the favor byposting a few things that might be useful for those wanting to add a switch tocontrol when the exhaust vacuum is operating. (If you have a V8 Vantage andyou've not removed Fuse 22 yet, give it a try. Make sure you get the right onethough...on my 2008 it's located where the red circle is in PIC1).
I put my button in the small flap covered ashtray like space, just forwardof the cup-holders (PIC10).
First, to avoid cutting any wires, soldering cables onto blades etc. considerusing this FuseSocket Connector from General Technologies part #
CT6100 CT6100
...$8. The spademale terminals needed to be bent so the fuse box lid would fit back on. Iconsidered using an inline fuse holder but opted to simply use spade connectorsdirectly on the fuse....should be fine (PIC8).
I routed the cables pretty much following the battery cable fromthe fuse box back to the battery compartment. You'll probably need to removethe panel that has the trunk RH light in it. Pop out the light lens with asmall flat head (be careful). You'll then see a small nut behind the lens thatneeds to be removed. Apart from that there's only a plastic pylon inserted intoa bracket holding the thing on. After the nut is off you can pull the plasticpylon out easily enough. Once off it will look like PIC2. I circled my cables.
So now you're in the battery compartment. Remove the aluminum bar runningacross the width of this area; not absolutely necessary but probably makes itslightly easier. Next, remove the rear center console section. There are 4, T25torx screws. The easy 2 to get to are under the rubber insert in the cup-holderspace (PIC3). Loosen them. There’ll be a metal plate underneath that which will falloff (you’ll see why in a second) if you completely remove them…no big deal. Theother 2 screws are under a small tray at the rear of the console. It’s a littletricky to get this off but using a hook or small flathead to pry it out (PIC4).Now wiggle and pull the console toward the back of the car. When it’s loose,disconnect the ipod and outlet cables.
In PIC5 you’ll see the front part of the center console. There are a coupleof screws at the rear and where I have circled there are a couple of tabs thatslide under the bottom of the dash. Remove the screws, wiggle, and pull back.Remove all the button cables (not easy to get the cables muddled up but worthmarking the lock/unlock and trunk open buttons). There will might be an extraunused cable there too…ignore it.
At this point it’s very easy to route your cables from the battery locationforward to the front center console area. I used a switch with an LED light for“On”, which requires a ground. One tip here is that the hot side of the fuse 22socket in the fuse box is toward the outside of the car. Knowing this willhelping you wire the switch correctly. I put some tape over the leather at the locationwhere I drilled the hole for the new switch to avoid damage. Before you puteverything back together test it!
Ok, now put everything back together again. The one tip I have here is usedouble-sided tape to temporarily attached the metal bracket that may havefallen off earlier during the rear center console removal. See PIC6 and 7 tosee how it should look.
That’s it…good luck and I hope this helped a little.
Old Sep 4, 2013 | 12:59 AM
DavidSD's Avatar
Pic6-10
The rest of the pictures 6-10
Old Sep 4, 2013 | 04:53 AM
Jibberingloon's Avatar
Jibberingloon is infamous around these parts
This is what we are all doing on the other side of the pond!
http://www.pistonheads.com/gassing/t...d%2E&mid=93255
Remote Switch you can have on a key fob
Old Sep 4, 2013 | 05:28 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Here's another thread for a wireless switch. Very easy to install, no wires to run, and easily reversible:
https://www.6speedonline.com/forums/...te-switch.html
Old Sep 4, 2013 | 06:47 AM
yankee04's Avatar
yankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond repute
I installed the Mild-to-Wild switch in my Vette. Simple five minute task.
Old Sep 4, 2013 | 05:27 PM
DavidSD's Avatar
I considered the wireless approach but didn't like the idea of the key fob (I use all 3 of the mirror buttons too). Absolutely I nice solution though.
Old Sep 17, 2013 | 06:32 AM
STILCARS's Avatar
STILCARS is infamous around these parts
Thanks for the pictures!
Old Sep 17, 2013 | 10:43 AM
DavidSD's Avatar
You're welcome Stilcars. If you decide to go the switch route (as opposed to wireless key fob) I hope it saves you a little time.
Old Sep 18, 2013 | 09:02 PM
astongirl's Avatar
astongirl is infamous around these parts
This is great! I still haven't found the time to simply pop the fuse out to see what it sounds like.... I will do that soon though....
Old Sep 19, 2013 | 09:55 AM
DavidSD's Avatar
You're going to really like it .
If you decide to add some sort of remote control, be sure to consider both the method I used (switch in the ashtray location) or a wireless key fob approach (links were provided earlier in this thread). Both work...really down to what type of "switch" you want and your comfort level taking stuff apart. Another key difference is that unless you replace something (like the power socket in the ashtray) you'll need to drill a hole. Many don't like doing this because it makes it more difficult to remove when selling the car.
Good luck and enjoy!
Old Sep 19, 2013 | 02:20 PM
astongirl's Avatar
Thanks David... May try to do that this weekend.... 2 car shows this Sunday :-)
Old Oct 5, 2013 | 07:16 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
all V8V have this exhaust? wasn't sure if all had a baffle setup.
Old Oct 6, 2013 | 08:30 AM
DavidSD's Avatar
Sorry Wa1l1in I don't know....but in all the posts I've read I've not heard anyone mention it wasn't posssible on their year V8V
Old Oct 6, 2013 | 11:50 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Stock exhausts all have bypass valves, most aftermarket exhausts don't. The bypass valves are required to meet European "drive by" volume tests that manufacturers have to meet. Aston are made to one spec that meets all worldwide requirements.
Old Oct 6, 2013 | 09:05 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
I hesitate to "pull" any fuses.... so I did disconnect the vacuum hoses to the bypass valves. I capped the 2 hose ends and both valves with small rubber caps. Took me 10 minutes (Attempt ONLY when exhaust/muffler is COOL). Baffles are now OPEN al the time. Easily reversible in another 10 min.
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Steven997TT
Aug 27, 2015 02:56 PM
Ferrari
Aug 24, 2015 04:35 PM
cerbomark
Aug 22, 2015 12:50 PM
