DB9 Trouble starting when fuel is low
Old Jan 15, 2014 | 08:32 AM
dallasbaker's Avatar
dallasbaker is a jewel in the roughdallasbaker is a jewel in the roughdallasbaker is a jewel in the rough
I have trouble starting my DB9 when there is 1/4 tank or less. It usually will not crank on the first try. Sometimes it can take 3. It cranks perfectly any other time. I have searched the forums with solutions.
Have any of you experienced this problem?
Thanks in advance!
2006 DB Volante
Old Jan 15, 2014 | 10:56 AM
karlfranz's Avatar
What do you mean it will not crank? Not cranking is an electrical system-related issue, not a fuel system-related one. Are you saying you push the starter button and nothing happens or does the engine turn over but just doesn't fire up?
Old Jan 15, 2014 | 06:26 PM
I'm sorry. I wasn't detailed enough.
The starter turns the engine over and it does so with plenty of juice.
I am wondering if it may be a fuel filter, pump or pickup issue.
Old Jan 16, 2014 | 10:02 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
The is any issue on early db9 that the fuel drains back into the tank. The fix is installing new fuel lines with check valves, from the fuel filters to the tank. All of this is internal to the tank. If you have a coupe this maybe costly, but if is a volante should be fairly reasonable.
Old Jan 16, 2014 | 12:50 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
I've had the "low fuel light" on a couple of times on my MY07 DB9. Happy to say never an issue starting. As always the education / info on this forum is appreciated. Thanks
Old Jan 16, 2014 | 12:59 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Keep the tank full.
Problem > Solved
Old Jan 16, 2014 | 01:24 PM
Originally Posted by drcollie
Keep the tank full.
Problem > Solved
Yep- lowest cost fix !
Old Jan 16, 2014 | 02:23 PM
Thanks.
For now I will continue to keep it over 1/4 tank. I may perform the fix when it warms up.
Old Oct 13, 2023 | 03:54 AM
bosiarz's Avatar
bosiarz is infamous around these parts
I have the same issue in my '06 DB9 Volante. With OBDII scanner I noticed that fuel pressure goes down very quickly when pump stops. Could you help me with a part number of the lines with check valves?
Old Oct 14, 2023 | 09:09 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
There's no part number for the check valve itself. It's integrated in the fuel pump. The pump up to '07 is on perpetual backorder last I checked. The '08 to '12 is orderable and physically fits, but the connector to the fuel pump will need to be swapped over from old to new. Otherwise the connector will fit on the filter, but the locking mechanism is incompatible.
Also, don't rule out leaking injectors. That will give you a similar leak-down symptom. Injectors are a lot easier and cheaper to replace.
Old Oct 19, 2023 | 06:04 AM
bosiarz's Avatar
Maybe you are right. I have also a lumpy idle (misfires). I wanted to change coils but maybe the reason are bad injectors.
To check injectors, I need to go to the workshop where they will do flow tests or I can check it by myself? It would be much easier.
Injectors are manufactured only for AM or fits also to the other cars?
Old Oct 23, 2023 | 05:33 PM
DB7GT's Avatar
5 Year Member
DB7GT is infamous around these parts
I had this exact issue with my 07 DB9. 1/4 and below, it wouldn't start the first time. Would always have to fully key cycle to eventually get it started. It ended up being a weak fuel pump for me. Just replace both while you're having the tank out.
GA_DB9
May 16, 2026 05:15 AM
zzzamdb9
Jun 21, 2023 02:08 PM
randyb
Aug 17, 2018 01:37 PM
randyb
Jan 8, 2016 07:59 PM
DonBond
May 15, 2013 08:33 AM
