Porterfield brake pad question
Old Feb 4, 2014 | 11:33 AM
PhoenixRising's Avatar
PhoenixRising is infamous around these parts
Originally Posted by XWCGT
911s and especially BMWs have NO WHERE near the brake caliper size. these are 14"" rotors. not the paltry 12-13s of the BMWs and earlier porsches. (porsche big reds were 13' rotors, but no where near the caliper size of the AM)
It also could be rotor material and finish, when new. the problem should go away with a good bedding and over time.
your bedding with medium stops, wont due much. they really have to cook to get the resins out of the pads and get a wear pattern on the surfaces.
I do this a lot, so i have quite a bit of experience bedding brakes for street and race. the only pads i cant get to stop squeaking is the full race pads like pagid RS14s or equiv. (pagid racing black). I can get pagid orange race pads to stop squeaking, but the rotors have to be new to begin with.
Thanks for the input! You're right about the smaller rotors and calipers on our other cars. And I'll try to get out on the highway and really push them to finish off the bedding process.
I also bought a set of those Red pads that people talked about on this site. MAN were those noisy. No matter what. I always had to brake hard very early, then barely touch the brakes to hopefully slow down in time or they both squealed like a banshee.
Old Feb 4, 2014 | 12:11 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Originally Posted by PhoenixRising
There are posts on this site that also complain about Carbotech pads squealing at low speeds. That was the reason I chose the Porterfields. I'm going to continue the bedding process. Wish me luck.
I also tried the Girodisc 2-piece rotors for the Ford GT after reading they should fit. Unfortunately that particular brand did not. It's been quite the learning experience.
If you still need rotors, I have 2-piece rotors in stock.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Feb 4, 2014 | 12:31 PM
I just got the stock ones. $600 vs $2000+ was too easy to pass up. Since it's just the squeaking that I wanted to stop.
Old Jul 19, 2014 | 02:58 PM
Quick update - the Carbotech 1521 pads for the front did the trick! Much less dusting and a LOT less squeal. I completed the bedding process and am so happy with the results.
I do notice occasionally the fronts will want to squeak a little upon first driving the car. What seems to work best for me is to perform a couple hard braking tests to wear off the pad material enough to silence them. Then I'm good for about another week. This was a pet peeve of mine with this car, and now I barely ever notice it. I am SO happy.
Now it's time to do the rear pads. I'm even going to do the parking brake pads as well. I've found the Carbotech pads for the rear rotors, but it seems that AM pads are all I can find for the parking brake. If there is anything you would suggest, please let me know. Thanks!
Old Jul 19, 2014 | 04:17 PM
ComoLakeItaly's Avatar
ComoLakeItaly is infamous around these parts
The fastest solution was to put a particular red rubber spray (I don't remember now the brand, I have to check at home) behind the pads, It works great ( I used it on my 3 motorbikes and 3 sport cars with racing pads and always worked fantastic, zero sound during breaking)
Old Jul 19, 2014 | 04:30 PM
GeorgeP's Avatar
GeorgeP is infamous around these parts
When I had the Vantage I was pretty pleased with the PF's.
Did have an occasional squeal during hard braking.
I may try the C.T.s on the DB9.
Let me know if those are continuing to work for you.
Thanks for the input.
Old Jul 20, 2014 | 12:36 PM
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
the handbrake pads are the same as S Type Jags:
http://www.ebay.co.uk/itm/JAGUAR-S-T...ht_1071wt_1037
Old Jul 23, 2014 | 09:37 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
You can send tour worn out pads (parking brake) to carbotech and they will refurbish it with carbotech 1521 compound.
I have front and rears done with slot for wear pad sensor too for my DB9
Old Jul 24, 2014 | 12:04 PM
That's a good idea, but it would take my daily driver out of commission while the pads are away. Also, I think since there's very little material on the ebrake pads I won't need to replace them.
The rears are on their way to me now. I should have it completed sometime next weekend. Thanks for all your help!
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
