DIY DB9 Seat Cover Removal
Old Mar 4, 2014 | 06:22 PM
dallasbaker's Avatar
dallasbaker is a jewel in the roughdallasbaker is a jewel in the roughdallasbaker is a jewel in the rough
If you want to access the lumbar support or heating element in your DB9;
1. Lean seat forward @ ¼ of the way
2. Pull release handle straight back to slide off. (it can be stubborn)
3. Pop out retainer in each corner of the rear seat storage flap
4. Pull flap down. It is Velcro on each side
5. Pop off plastic side cover. Notice pin in picture
6. Unplug air bag connector
7. Remove bolt and pull down and out to remove side air bag
8. Pull side leather inward and back.
9. Using a screwdriver, pry off the lower back plastic strip of the suede pieces
10. Starting on one side, pull the edge out from molding. Most of it is held in by metal clips.
11. Push back flap through the seat bottom. (careful not to scratch)
12. The front of the seat is held by Velcro tape within the folds. Using one hand, hold the velcro down, while pulling with the other. The velcro can come off the foam. It is pretty stout, so use a little force.
13. Finally, slide the seat cover off the top, working it side to side.
Now you can access your lumbar system. I was nervous at first, but the whole process was fairly simple. Take your time with it. It took me about 15 min per seat.
I will release part 2 of this post later in the week, explaining why I went through all of this trouble.
ID:	341995   Click image for larger version
ID:	341996   Click image for larger version
ID:	341997   Click image for larger version
ID:	341998   Click image for larger version
ID:	342000   Click image for larger version
ID:	342001   Click image for larger version
ID:	342002   Click image for larger version
ID:	342003   Click image for larger version
ID:	342005   Click image for larger version
ID:	342006   Click image for larger version
ID:	342007   Click image for larger version
ID:	342008   Click image for larger version
Old Mar 4, 2014 | 07:36 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Very informative post; should work for the Vantage seats as well...rep points gladly added!
Old Mar 4, 2014 | 07:46 PM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
Nice one Dallas. Bookmarked
Jul 29, 2019 11:13 AM
DonBond
Apr 16, 2016 07:55 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
