DB9 Driver Door Alignment Issue
Old Mar 7, 2014 | 12:37 PM
jyu12's Avatar
jyu12 is infamous around these parts
Im having an issue with the driver door on my 07 DB9. Whenever it gets wets the window squeals when being rolled up or down. I investigated a little more and notice that the door is slightly out of alignment. Just wanted to see if anyone have had the same issue and what the fix for it is.
Old Mar 7, 2014 | 01:39 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I solved my squealing window problem by applying SwissVax Seal Feed to all the rubber around the window & especially at the top of the door.
Don't know anything about door alignment though.
Old Mar 7, 2014 | 02:46 PM
jyu12's Avatar
Hi YVR Is there some where local I can purchase the SwissVax Seal Feed
Old Mar 7, 2014 | 03:02 PM
Aerome's Avatar
Aerome is infamous around these parts
http://www.swissvax.us/product/SE1023110.html
But I'll bet your local GM dealer has something similar for a sane price.
Old Mar 8, 2014 | 07:20 AM
yvr's Avatar
yvr
No local source that I know of -- I had it on my xmas wish list & Santa came through I think the online seller shipped from Florida.
Definitely an expensive product but the bottle should last me many years. I'm sure there are less costly options. Aerome is right, GM used to have a similar product but I haven't been to a GM dealer for years.
Old Mar 10, 2014 | 11:49 AM
jyu12's Avatar
I was able to align my doors a little better by adjusting the door catch plate on the door sill. After loosening the two torx bolts there is about 1/2" of lateral play. I adjusted the plate to a flush position the tighten the bolts. The door now is aligned perfectly at the top where the catch plate is but the bottom of the door is still a little off.
As for the window squealing. I sprayed some autoglym vinyl and rubber care around the rubber surrounding the window and also around the weather strips on the door seems to have solved the problem but not sure how long it will last until I have to re apply
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
Zero911
Aug 24, 2015 06:51 PM
