10W-60 full synthetic what brand?
Old May 5, 2014 | 01:25 PM
telum01's Avatar
Originally Posted by karlfranz
This is how I buy Castrol too. If you ask the guy at the BMW parts counter nicely, you can get it for $13.50 all the time.
Originally Posted by yankee04
I don't have a buddy but that's also the price I pay.
I have a feeling there's some shenanigans being had here... I might need to have a chat with my friend
Still, better than the $18+ I've been charged by the AM dealer that used to do my service before I moved to VA.
Old May 5, 2014 | 01:55 PM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
Nope I just wanted to have some on hand to top it up. It actually had all fluids replaced late Dec 13 including oil change, so I'm good to go for awhile, but I know that they tend to use a bit of oil.
Glad to be of service. But didn't you just get your car this weekend? Do you need an oil change already? I would've thought the dealer did this for you—unless you drove 10,000 miles this weekend, of course.
Old May 5, 2014 | 02:06 PM
karlfranz's Avatar
I think telum's "buddy" has been using the ol' car salesman line "Because it's you, the price will be…".
Old May 5, 2014 | 04:56 PM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
I change oil every 3 to 5k miles. Have done this for thirty years. Old habits die hard. When i see (or think I see) the oil change color at all, I change it. With as rich as the 07 v8v runs, the oil could possibly be getting contaminated. i prefer to maybe err on the side of caution. As far as breaking down, one of our former engine builders would only allow oils a specific time duration and/or heat cycles (like tires). BTW, I know technology has change but the Vantage filter seems kinda small.
Old May 5, 2014 | 05:14 PM
karlfranz's Avatar
^^^^ Yeah, you really need to kill that old habit. There's no reason that you should have to change the oil more frequently than 1 yr/10K miles unless your engine is being subjected to extreme conditions. Of course, there's no harm done to your car by doing it sooner, just to your wallet.
Old May 6, 2014 | 10:05 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
How much things have changed. For my Porsche Boxster the Oil change recommendation was Once a year or 15,000 miles--Filter to be changed every-other Oil Change. A small filter isn't of concern with oil--it's depletion of the additives. So Oil Change of once a year or 10,000 miles on the Aston, with such a High-Quality Oil, seems very reasonable to me--And to the Factory who recommends it. Remember also in earlier cars there were only 4-5 quarts in the Crankcase--the Aston has about 2-times that. Just another reason it can go longer between changes.
Old May 22, 2014 | 11:12 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
Originally Posted by telum01
The stuff for your M3 should be the same. It's the Castrol Edge Professional (not Sport). I have a buddy that works at the local BMW dealership, so I get it for $13.50
what is the difference between the sport and the professional?
I've seen 3 types of oil for the 10-60.
what ever happened to the racing oil and then the normal high end oil as being the two categories.
Old May 23, 2014 | 04:52 AM
rscultho's Avatar
rscultho is infamous around these parts
Interesting. The dealer told me that for my engine I should use 5W/30.
Did not know there would be that much difference in oil for the 8 and 12 cylinder engines.
Old May 23, 2014 | 05:23 AM
der Fahrer's Avatar
der Fahrer is infamous around these parts
XW, I am fairly certain that "TWS Motorsport" is simply the older label for the "EDGE Professional" bottle. I had used TWS for years in my M3 and when they switched labels I had to quiz my dealer to make sure that the "EDGE Pro" truly was the right one to use.
Old May 23, 2014 | 07:43 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Castrol edge for BMWs is your best bet for 10w-60. Although that is a very heavy oil weight, not sure why you are running a weight that heavy, it's a bit overkill unless you are racing.
On low mileage exotics, the general rule of thumb is once a year. Pick a date and change oil on that date every year regardless of mileage. You don't want the same oil just sitting in there for years even if you don't put any mileage on it. Like any other fluid, it goes bad over time even if you use it or not.
Old May 23, 2014 | 08:18 AM
karlfranz's Avatar
10w-60 is the correct weight for the V8V. Why would you use a different weight than the one recommended by Aston?
Old May 23, 2014 | 09:25 AM
XWCGT's Avatar
You couldn't get a bigger difference between engines! Different pistons, heads, cams, cranks, rods, etc..... so, different oil.
Old May 23, 2014 | 09:42 AM
The BMW Castrol 5w-50 is a much better motor oil and is put in more of their performance oriented models. 10-60 is just too heavy for most winters, whereas 5w-50 is technically a true year round oil you can run 12 months a year. Plus 10w-60 makes the motor rev like a slug, 5w-50 definitely makes the motor more free revving and provide superior protection on cold start.
Old May 23, 2014 | 09:57 AM
XWCGT's Avatar
you don't want to spin a bearing with a too light weight oil. the design says 10-60, I would stick with that.
Plus, this engine is designed for 60 weight oil at temp, at temp , it doesn't matter if you are in Antarctica or in mexico. your operating temp is your operating temp. so, I would stick with 10-60 as the oil for all seasons especially in this engine with racing root design. (tight tolerances and clearances.
all the BMW higher performance engines recommend this oil . (same as us with the AMV8) no one is using the lighter oils in the M series BMWs)
Here is the actual tests of the two oils from the BMW thread. Billy Johnson (pretty well known amateur turned pro racer from cali) actually sent in the two oils to Blackstone for analysis.
http://www.m3post.com/forums/showthread.php?t=926080
Old May 23, 2014 | 02:14 PM
telum01's Avatar
copy/paste from the other thread:
From what I've seen, comparing current info to what I was seeing some months ago when I was looking into this...
TWS was the good stuff that the BMW guys loved. The formula was updated and it is now Edge Professional. Edge Professional is generally only marketed to dealerships/garages/shops. If I remember correctly, TWS was the oil AM originally had in the V8 Vantage when they first brought it to the US.
The lower grade (or the one with fewer or different additives) was the Syntec RS, which then became Edge Sport. Edge Sport was marketed toward consumers.
Edge Sport was reformulated again to add Castrol's FST additive (or whatever it is), which is supposed to improve the performance of the oil over its lifespan. FST is already in Edge Professional. Edge Sport is now called Edge FST.
With its new formula, it *seems* like Edge FST is now on par with Edge Professional, with the primary difference being marketing.
