Fender hood seals on vantage
Old May 6, 2014 | 02:06 PM
karlfranz's Avatar
You can lower the bonnet just past the catch, then drop it (about 2 inches). This keeps the seals straight without palm prints. If it doesn't fall with enough force, you can give it a little help by pressing down as it falls. Just do this at the leading edge of the bonnet where a palm print won't be noticeable.
Old May 7, 2014 | 07:32 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Another suggestion
My dealer mechanic, with myself and 2 visiting AM techs in his audience, suggested we tug on the offending section of the seal, stretching it laterally a bit into the engine compartment.
Dropping the hood from a couple of inches works fine as well.
Old May 16, 2014 | 03:48 PM
keitheva's Avatar
keitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of light
Fender make guitars, it's a British car, it has wings
Old May 16, 2014 | 05:37 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
usually if the adjustment of the screw out and in rubber hood stops are off, the seal wont be flush and the hood will fall too low. (forcing the seal to pop outward).
the screw in rubber gromets are usually all the way extended. and sometimes that is not enough, so I put a couple of cork/felt pads where they make contact to raise the hood. is this normal?? its perfect now, but without the pads, it isn't.
Old May 20, 2014 | 04:48 PM
tko211's Avatar
tko211 is a jewel in the roughtko211 is a jewel in the roughtko211 is a jewel in the rough
+1 on the easing the hood down till just about where it catches and then dropping it. I have found that it keeps the seals under the hood / bonnet.
Old Jun 20, 2014 | 02:32 AM
XWCGT's Avatar
I just lower it til it rests on the latch, and press gently on the emblem to make it "catch" and click into place. that is the best way to do it. slamming the hood is so barbaric! Just , lower and press. its like jewelry. its not a ford mustang for cripes sake.
Old Jul 1, 2014 | 10:07 AM
Conqueror's Avatar
Conqueror is infamous around these parts
While closing the hood gently works, I have a section on the drivers side that works it way back out in a few weeks.
Old Sep 16, 2014 | 11:39 AM
karlfranz's Avatar
Just thought I'd mention that on newer cars Aston has solved this problem by changing the profile design of the rubber seal and making the rubber more rigid.
jaehoppa
Oct 22, 2015 09:17 PM
XLR82XS
Oct 5, 2015 07:02 AM
Texas1
Sep 20, 2015 09:12 AM
BLKMGK
Sep 19, 2015 03:51 PM
sparks
Sep 8, 2015 03:03 PM
