Different brake rotors
Old Jan 5, 2015 | 08:36 AM
  #31
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Karl thanks for reminding me of this one!
Last question
Are the front pads a common part on the floating and dual cast rotors?
Old Jan 5, 2015 | 11:04 AM
  #32
karlfranz's Avatar
The 6-piston calipers and brake pads are the same for:
  • all V8 Vantage S;
  • all V8 Vantage from 12.25MY to current
  • all Vantage GT/N430
All V8 Vantage S use floating discs.
Regular V8 Vantages built between start of 12.25MY (changeover to 6-piston front calipers) and October 2013 used the same floating discs as the V8 Vantage S.
Regular V8 Vantages built since October 2013 use the dual-cast rotors.
All Vantage GT/N430 use the dual-cast rotors.
Old Jan 9, 2015 | 10:05 PM
  #33
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
Originally Posted by karlfranz
The 6-piston calipers and brake pads are the same for:[*]all V8 Vantage S;[*]all V8 Vantage from 12.25MY to current[*]all Vantage GT/N430 All V8 Vantage S use floating discs. Regular V8 Vantages built between start of 12.25MY (changeover to 6-piston front calipers) and October 2013 used the same floating discs as the V8 Vantage S. Regular V8 Vantages built since October 2013 use the dual-cast rotors. All Vantage GT/N430 use the dual-cast rotors.
Are either the dual-cast or 2-piece rotors more resistant to the dreaded hub rust of the older ones? Is it possible to update my early-2012 V8V to the later, post-12.25MY larger rotors and calibers?
Old Jan 10, 2015 | 11:22 AM
  #34
mikey k's Avatar
The 2 piece ones are, though the rears are the same so still bad
Rguy
Apr 12, 2020 11:11 PM
HIGHcard
Sep 24, 2015 08:09 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
