Leather coming off..how to take this piece off?
Old May 10, 2015 | 07:31 AM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Grab hold of the back corners close to the windshield and pull upward firmly . Once the back is free repeat above the instruments and its off . Reglue the leather .(I Used an epoxy ) and it looks as good as new . total time to repair less than an hour and it didn't cost 250$
Old May 11, 2015 | 03:03 PM
rohnin's Avatar
rohnin is infamous around these parts
I wonder if this leather dash problem has been fixed for later models..
Old May 14, 2015 | 12:08 PM
911MTB's Avatar
911MTB is infamous around these parts
I believe there are a few threads on this. From what I gather AM updated the glue they are using and it has not been an issue on the newer cars.
Old May 14, 2015 | 12:26 PM
PureNick's Avatar
PureNick is infamous around these parts
Leather upholstery, if you find the right people, isn't really too expensive. Through Aston or any high lux brand for that matter, it's insane haha. BUT this makes for good negotiating skills when buying a used Aston that happens to have that damage cause 99% of the time they'll warrant a discount on the price at the cost of replacement as if you were going through Aston... like in my case
My current Aston had leather shrinkage on every dash panel including the air vent pieces. I did the leg work and removed all the panels which saved me probably 3-5 hours of labor but then had a shop in Tampa, FL do the everything thing for $650. They replaced all of the leather and matched the stitching to the factory. Black leather with silver stitching which is easy peezy. It was done in 3 days.
Old May 14, 2015 | 12:39 PM
karlfranz's Avatar
Given enough heat, all automotive trim adhesives can fail. So, if you live in a hot climate and leave your car baking outside under the sun, this can be an issue even with the newer cars.
Old May 15, 2015 | 12:46 AM
rohnin's Avatar
I wonder why they don't just rivet or staple/stitch them down?
Old May 15, 2015 | 01:04 PM
karlfranz's Avatar
This is an issue with all cars, not just Aston. Leather is usually stretched around the edges and glued from the underside. Using staples or rivets would show through the top side.
Also, without adhesive, the leather will still stretch, but the holes from the staples or rivets would cause it to tear.
The contact cement used provides the largest surface area for maximum adhesion, but shrinkage from extreme heat can overcome its ability to hold.
Fixing it, however, can usually be done rather easily by re-stretching and re-gluing the leather to the substrate.
COBB Tuning
Jan 1, 2025 09:02 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Money2536
Sep 1, 2015 04:56 AM
gulf gt
Aug 27, 2015 10:27 AM
pwdrhound
Aug 23, 2015 07:36 PM
