Headers + Filters + ECU from VelocityAP
Old Jun 23, 2014 | 08:03 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Originally Posted by ArtB
I too will be dyno'ing my stock Vantage tomorrow. My baseline was 311hp at the tires on a 248C. I am installing the Velocity ecu tune as well, but no headers, my car is completely stock from a performance standpoint. This should give a good idea of what the stock system will be capable of with the ecu alone. More mods later. I will post video etc too and impressions once it's all done.
Art
Since the HP curve is still rising at 7,300 RPM, it would be great if the limit was set at about 7,600 RPM instead.
Old Jun 23, 2014 | 09:52 PM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
Yes, The final tune is a 7700 rev limit tune. The power drops off a bit, but check out my thread on the "velocity ecu". I think that the person that was writing the tune probably took the 7500rpm map and trasncribed it to make the 7700rpm tune, but forgot to add a bit of timing back in above the 7500 rev limit from the previous tune. The power continues to climb nicely past 7500 but hits 7600 and starts to fall. Tells me the timing isn't staying advanced. The AFR stays the same which I have on a different log graph in Volts from a Motec Wideband ecu.
Art
Old Jun 24, 2014 | 07:20 AM
Jeremyosj's Avatar
Jeremyosj is infamous around these parts
Art
Hi Art, what sort of A/F are you running?
Old Jul 20, 2014 | 11:42 PM
Jeremyosj's Avatar
Dyno results
From Stock (Blue line) to headers, decat, filters & ECU (Green Line)
Peak power went from 304whp to 330whp.
Red line is only ECU tuning.
Torque seems to down in the 3-4k range. Anyone with same experience?
The headers change the sound of the exhaust note and combine even with the stock exhaust it makes a lovely sound
Will post some sounds videos when I have the time.
Name:	aston dyno 3.jpg
Old Jul 21, 2014 | 08:09 AM
biggynuts01's Avatar
biggynuts01 has a spectacular aura aboutbiggynuts01 has a spectacular aura about
What mods are done with the red line?
Old Jul 22, 2014 | 08:11 PM
Jeremyosj's Avatar
Only ECU tuning.
A stock 911 2006 C2 did 273whp on this dyno
The mileage between the base line and final dyno (green line) was about 300miles
Old Oct 14, 2014 | 01:23 AM
Jeremyosj's Avatar
Custom X pipe installed
Xpipe in place of the Cats
I found running the exhaust note with out the cats on a little to high pitched and jarring. So I just got a custom x pipe made.
Will send a video in the next post.
I recently had a good drive together with a V8 4.7 and my 4.3 was just as fast at speeds above 100mph
Old Oct 14, 2014 | 06:15 AM
Unhappy
I recently installed Harrison Signature 200 cell cats and with fuse 22 pulled it was much too loud for our liking. Its sounds amazing at mid throttle but at full load its really loud so i just went back to stock....but now its too quiet
I wonder how it would sound if i put fabspeed x pipe on
Old Oct 14, 2014 | 08:50 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I always wanted to do "X cat" (or X-cat bypass in this case). Please do an after dyno, I am dying to know what the gains are various rpms.
How does it sound now that you put X pipe in with headers?? (It should sound smoother now).
Old Oct 14, 2014 | 09:39 AM
Jeremyosj's Avatar
Here is a sound clip from a quick pull with the windows down.
Clutch out crawling in 1st then flooring the throttle, 2nd and a little of 3rd.
https://www.dropbox.com/s/4hf64h7lwq...xPipe.m4a?dl=0
Old Oct 14, 2014 | 05:52 PM
car sounds awesome. Not sure I can detect how loud it actually is from the clip.
Old Oct 15, 2014 | 09:22 AM
Jeremyosj's Avatar
When the valves are open, its really loud outside the car. Essentially, valves open = nearly straight through from engine to exhaust tips with no mufflers/cats in between. The note is not vulgar, nor brutish like Lambo's, not screaming like the Ferrari's, not with the rumble of AMGs but more like a opera tenor building to a climax.
Old Oct 15, 2014 | 03:18 PM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
I put the x-pipe fabspeed and the sound is fantastic ...
I put some videos if interested
Old Jan 14, 2015 | 06:42 AM
Sorry the long delayed reply. I know you have the BR GT4 engine but what else have you done to your exhaust? I may consider the fabspeed xpipe.
Old Jan 14, 2016 | 08:31 PM
Jeremyosj's Avatar
Just sold my 2007 Vantage V8 4.3.
I have the the headers and x-pipe out of the car.
Any body wants to buy them from me?
Setup works best with a tune from Stu.
