Removing Emissions Light with High Flow Cats
Old 06-18-2014, 05:31 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
I have some Magnaflow High Flow Cats 200 cell and the light keeps coming on after 2 / 3 starts.
I have read that it can take up to 8/9 starts for the ECU to stop detecting this but I have tried that a few times and still the check light comes on.
I read somewhere there was a mini bung that interfaces between the o2 sensor and the cat and has a mini catalyst mesh to fool the sensor. I cant remember the name and google doesnt come up with anything.
Does anyone know what this is called? Or have any other ideas. i.e. a resistor in the wiring perhaps?
Old 06-18-2014, 07:31 AM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
You can switch the warning lights off with an ECU remap, but you can also use O2 sensor spacers/lambda cheats. We can send you some lambda cheats if you like, hold them in stock in the UK.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old 06-18-2014, 07:37 AM
Vergis's Avatar
Already have the extension bungs on the O2 sensors so that the sensor is more removed from the gases.
Think I might have found the solution here (although I would prefer some metal substrate):
http://www.ebay.co.uk/itm/310574328534?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 06-18-2014, 07:47 AM
http://www.ebay.co.uk/itm/3105743285...%3AMEBIDX%3AIT
I'm at Top Gear right now, they own half of Velocity. Those are the ones I was talking about.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old 06-18-2014, 07:48 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
O2 spacers
Old 06-18-2014, 08:10 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Going to do the full writeup on cats today, these have fully build in cat defowlers. Check with the MD802 to see how far the cats are from the threshold and they are not even close... Will explain in the writeup.
Old 06-19-2014, 10:42 AM
Jeremyosj's Avatar
Jeremyosj is on a distinguished road
Old 06-19-2014, 11:14 AM
Posted review, read the "Cat stats" section and you will see what the Catalytic Test threshold is vs. actual reading with the built in defoulers for a 200 cell high flow cat. you can buy a set of screw in types for your cats but the fitment may be an issue as space is pretty tight down there.
https://www.6speedonline.com/forums/...ics-dynos.html
COBB Tuning
01-29-2022 09:42 AM
ModBargains
08-20-2015 12:28 PM
oddjob142
08-19-2015 12:27 PM
Quick Reply: Removing Emissions Light with High Flow Cats
