What do these pipes do?
Old Jun 24, 2014 | 04:44 PM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
The 2 pipes that attach to the right of the air induction pipe ?
Old Jun 24, 2014 | 08:11 PM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
The lower pipe goes to the valve cover, it is a crankcase breather hose. I suspect the upper hose in the picture is for the throttle body bypass. At idle the throttle body is almost completely closed, but there is a hole before the plate and it usually goes to a bypass into the intake manifold to allow the car to idle with the throttle plate closed or almsot fully closed. I have not taken a close look at my car, but that seems most logical from the picture. There isn't much reason other wise for the induction system to go under the intake manifold unless it was going to the other bank of cylinders, which I know that hose doesn't do.
Old Jun 24, 2014 | 08:43 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I believe Art is correct on both accounts. First one is definitely crankcase vent hose, you can see it go straight to the valve cover.
Old Jun 25, 2014 | 11:44 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Art is right on the one. The other pipe goes to the air pump under the intake manifold.
Appoli1313
Feb 14, 2017 06:09 AM
proTUNING Freaks
15
Jun 30, 2016 08:05 AM
cabman4007
Sep 28, 2015 03:25 PM
Greehn
Sep 16, 2015 04:45 PM
Sales@RSW
Sep 16, 2015 06:03 AM
