- BG Stop Squeal: Finally a cure for Aston Martin Brake Squeal issues -
Old Nov 16, 2014 | 02:59 PM
  #31
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Porterfields = zero squeal
Old Nov 16, 2014 | 05:49 PM
  #32
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Haha I was out with a girl last night in the aston and she said my brakes sounded so ghetto every time we come to a stop
Old Nov 17, 2014 | 11:56 AM
  #33
koolkat1973's Avatar
koolkat1973 is infamous around these parts
I installed Porterfields a little over a month ago. No squeal at all until last Friday when I started hearing it again. Hopefully - that was a fluke. Haven't driven the car since then.
Old Nov 19, 2014 | 04:04 PM
  #34
PhoenixRising's Avatar
PhoenixRising is infamous around these parts
I just applied the BG Stop Squeal to the fronts which are Carbotech 1521. I'm still hearing the squeal, but I'm going to let the car sit to see if the pads need more time.
Anybody have over 6 months with this on them? I'm curious if this truly lasts and lasts for the life of the pad? I saw that koolkat1973 didn't have the same results as others.
I'm keeping my fingers crossed!
UPDATE - I ran an errand and heard my brakes squealing again. Now I thought this was ALWAYS a front brake issue since I could swear I only heard it reflecting from the front of the car. Color me wrong! They were sounding off from the back this time. I'm not sure if all of them were making noise or not, but I was sure after having done the fronts that this was DEFINITELY the rears now.
I just finished applying the fluid to the rear pads (3 coats to be safe - haha) and my test drive was fantastic. I think they could see my smile in California. This stuff, at least for the time being, WORKS.
I'll be updating my findings as time goes by. Thank you, 007 Vantage, for helping get the word out about this. Aston's achilles heal (for me at least) may finally be fixed.
Old Nov 20, 2014 | 07:10 AM
  #35
telum01's Avatar
Another thing to consider is the e-brake pads. Not sure if that applies to your experience specifically, but when those squeak it sounds like it's coming from the front of the car even though it's actually coming from the rear.
Old Nov 20, 2014 | 07:21 AM
  #36
Luckily that's not a problem for me. When my brakes squeal, I usually go straight for the ebrake to stop the car in those noisiest last few feet. That's always a silent solution, luckily.
Old Nov 20, 2014 | 08:44 AM
  #37
karlfranz's Avatar
^^^^ Which means it could be the e-brake since applying it would cause it to stop squealing.
Old Nov 20, 2014 | 09:19 AM
  #38
Ah! We'll see if the issue returns. I think we've all gotten so good at brake jobs on this car that doing the e-brake would be quick and painless.
Although since the squealing would only happen at specific braking pressure and speed, I doubt this would be the e-brake. I can reduce braking pressure during the squeal and make it stop. Also sometimes I can overbrake to prevent it. I would imagine the e-brake noise would happen regardless of foot brake pressure, correct?
Old Nov 20, 2014 | 10:53 AM
  #39
karlfranz's Avatar
The e-brake noise usually manifests itself as a mouse-like squeak most noticeable when making low speed turns.
Old Nov 20, 2014 | 11:21 AM
  #40
That's good to know. It's not my current problem thank goodness. And a nice drive this morning was 'eerily' quiet during all my stops. I'm so happy with the results!
Old Jan 14, 2015 | 12:08 PM
  #41
I wanted to report back. After almost two months of daily driving the brakes are still perfectly quiet! This stuff is amazing.
Now here's the funny part. I called my SA at Scottsdale Aston Martin to let him know of this super inexpensive solution. I figured he's tell me there's no way AM would condone putting any fluid on the friction material. But he actually said they apply BG Stop Squeal to EVERY pad that gets changed at the dealership! It's just part of their duties during a brake pad job. I had to laugh.
Here I was trying to do work myself to save a couple dollars and enjoy working on the car. Turns out I wouldn't have had this issue had I taken it to the dealer in the first place.
Old Jan 14, 2015 | 09:06 PM
  #42
Jeremyosj's Avatar
Jeremyosj is infamous around these parts
I have been using Porterfield from Stu for 7 months with hard driving and I am happy to say that they are still squeal free
Old Mar 24, 2015 | 12:24 PM
  #43
It's been 4 months now since the Porterfields were installed to both front and rear and absolutely no brake squeal at all.
Old Mar 24, 2015 | 02:19 PM
  #44
karlfranz's Avatar
I have been using Porterfield R4-S pads for almost 20 years with no squeal and significantly less dust than OEM brake pads.
Old Mar 26, 2015 | 09:17 AM
  #45
mindscape9's Avatar
mindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to all
FWIW, I was having some brake squealing on mine as well. MY12.25 with about 8K on it. No squealing in the summer, but it got really bad when the temps started dipping below 50ish.
i asked the local dealer about it and they told me to try the bedding in procedure. Did it and it didn't help.
Took it in to them this week so they could check it out and they ended up chamfering the edges of the stock pads to stop the squeal. Told me that the squeal had something to do with the pad edge hitting the rotor at a 90 degree angle and hitting any debris that might be on the rotor.
So far so good and this fix was covered under warranty using SB06-0344v2.
