SatNav update DB9 2005
Old Jul 6, 2014 | 06:51 PM
bidcleary's Avatar
bidcleary is infamous around these parts
Smile SatNav update DB9 2005
Can a kind member point me in the right direction looking for an update for my satnav...thanks
Old Jul 6, 2014 | 07:01 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Go to navigation.com (used to be navteq). Order the discs for a 2006 Volvo XC90. They work like a charm, and you don't lose the Aston logo on startup.
Old Jul 7, 2014 | 09:10 AM
bidcleary's Avatar
Thank you yvr I have placed my order, I will let you know how it works on my 2005...cheers
Old Jul 8, 2014 | 11:11 AM
bidcleary's Avatar
Just received and installed my updated version...works great, only thing missing is the AM logo on start-up, but we can live with that. Very fast shipping from Navigation.com the discs arrived the next day.
Thanks again vyr with out your help I would have been going in the wrong direction looking for an update, no pun intended
Old Jul 8, 2014 | 11:44 AM
yvr's Avatar
yvr
The AM start up logo seems a bit random. Seems to depend on whether Nav was on when you last shut off the car. Have never figured it out and never worry about it.
At least it never says "Volvo"
Old Jul 8, 2014 | 05:34 PM
Conqueror's Avatar
Conqueror is infamous around these parts
Does the upgrade change how well it works or just updated maps?
Old Jul 8, 2014 | 08:10 PM
bidcleary's Avatar
it is early days as I have not had time to use the GPS with the updated program, however I did notice that I could use the joy stick to move around the map and pin point a location and then set as a destination. I have only had the car for a couple of weeks so I am not sure that function was available before...I don't think it was but I could wrong.
once I have put the new update though it's paces I will give you an update
Old Jul 9, 2014 | 09:46 AM
bidcleary's Avatar
Yvr, Conquerer have you had any issues with changing the trip meters from 1 to 2 and zeroing them, also I cannot change the LED speedo from kilometer to miles even though I follow the manuals instructions. The manual says to use the buttons on the navigation cluster T1 T2 to go from trip 1 to trip 2 and to hold for more than 3 secs to zero, to hold the read button along with the button on the signal stalk to change the trip computor dislpay units, not sure what the read botton does?
PS, the AM logo appeared on the screen!
Old Jul 9, 2014 | 10:08 AM
yvr's Avatar
yvr
I never really use the trip meters, but I've accidentally zeroed them while fiddling around.
I do switch between digital MPH and KPH regularly when crossing the border -- hold the button on the signal stalk while pressing and holding the "read" button for about 2-3 seconds. BTW -- this doesn't affect the ODO or trip meters, just the speed display.
Old Jul 9, 2014 | 10:36 AM
bidcleary's Avatar
i must have an issue with both T1 T2 and read buttons as they are not changing the settings...like you the trip meter is not a big deal but i too like to change to MPH when i cross the boarder, I will have to take it in to the shop...thank you!
Old Jul 9, 2014 | 11:17 AM
yvr's Avatar
yvr
Have you got the key in the right position? I usually switch the speedo while the car is idling at the border crossing.
Old Dec 23, 2015 | 10:57 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Which system did you choose?
MMM+
MMM/P2001
Old Dec 23, 2015 | 12:01 PM
bidcleary's Avatar
SatNav update 2005 DB9
MMM+
MMM/P2001
The SatNav update was for a Volvo C70 my06-07 they may have a more up to date version, this update is seamless to the Aston Martin SatNav
Old Dec 23, 2015 | 12:08 PM
randyb's Avatar
So you did not have to select a system then?
Now you have to select a system and am not sure which one to select.
Old Dec 25, 2015 | 08:03 PM
randyb's Avatar
Never mind, I was looking at euro disks.
pshep138
Oct 6, 2015 11:58 AM
Ekaplan1020
Sep 12, 2015 08:23 PM
Wildcat1212
Sep 7, 2015 11:31 AM
zuman
Sep 3, 2015 08:27 AM
