How To: DIY MAF Sensor Installation
Old Dec 28, 2016 | 03:40 PM
handyman2009's Avatar
Veteran: Canadian Forces
Thanks BMW-North great tips, I am sure I will have to replace mine some day...
Old Dec 28, 2016 | 05:01 PM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
I'm betting you never need to replace them. These items seldom need replaced. Most often (on BMW's anyway) it's typically owner intervention that causes it. (Use of oil based air filter or the use of a non-compatible cleaning solvent)
I cleaned my old (AMv8) ones with carb cleaner/compressed air and they worked fine (Do not use brake cleaner) - but for $82 I replaced them with new and now have two spares (the originals).
Old Dec 29, 2016 | 06:57 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Originally Posted by flinder
Telum, Reading through your excellent DIY MAF Sensor Installation thread a relevant thought occurred.
Might I achieve the benefits of AM's Airbox Solenoid hardware without its cost or complexity?
Can I drill a few well placed holes in each of my airboxes, effectively providing a short, supplementary intake air path for my hot rod 07 Vantage?
It sure appears doable...your opinion please.
The factory power pack included not only the intake flaps but also a retune of the ecu. Without test data, it's hard to say which of these is the more impactful modification, but I suspect it's the ecu.
I agree with Richard that water intrusion needs to be minimized, but the risk of hydrolock is only present if the intake is completely submerged. Think about trying to pull water through a straw when only half of the straw opening is in the water or if there is a hole in the middle of the straw. All you get is air.
Evey time a car is driven in the rain the filters get wet, but there.is no risk to the engine. So I don't see drilling more holes in the intake or removing the box altogether as an increased risk of water intrusion damage.
Water is sometimes intentionally injected into the charge of an engine to cool the intake and resist detonation, so it is not inherently damaging to an engine to injest water, but of course this is in a controlled manner.
Old Jan 30, 2024 | 08:09 PM
sweet991S's Avatar
5 Year Member
sweet991S
100% from the K& N. I know this all too well. Ask me how (not really - trust me).
Old Jun 8, 2025 | 01:04 PM
manuel2171s's Avatar
manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s
FoMoCo 3W4Z12B579AB so this is the correct maf sensor reference for all v12 ? its good for the rapide too? if i buy this one its same as eom?
https://spareto.com/oe/3w4z12b579ab
Harry Da Hamster
Dec 8, 2017 06:57 PM
djben
Feb 2, 2015 08:03 AM
Fozzybear
Nov 4, 2011 09:32 PM
Harmony Jim
May 14, 2010 08:41 AM
jalmood
Apr 18, 2007 02:14 PM
