07 Vantage ASM signs of a dying clutch?
Old Sep 15, 2014 | 08:48 AM
dmose's Avatar
dmose is infamous around these parts
Unhappy 07 Vantage ASM signs of a dying clutch?
Greetings,
37,000KM on my 2007 vantage ASM.
Last week I noticed my upshifts started 'lagging' - meaning, I'd upshift and instead of a rather instant change, the engine would rev a bit...then the gear would engage. This was especially terrifying on the highway going from 3-4th etc. Downshifts seem to work fine.
After a few days of this..last night I was driving to a stop, put it in N and tried to shift into 1st, and it wouldn't engage. I stopped/started the engine a few times to learn the clutch and it finally got into 1st.
This is the first time this has happened to the car. I would hear an occasional griding under the body in 1st gear that would go away after a while but it came back last week and now I think the clutch and/or transmission is finally dead.
During my last service my dealer said the clutch was dying.. so my question is, is that a sign of a dead clutch or is it a some other transmission issue?
Dealer wants 9k for the replacement
Old Sep 15, 2014 | 08:49 AM
dmose's Avatar
Also I will add - most of the KM is nasty city driving, stop start in 1st/2nd... up / down in steep parking garages - basically everything that people say will kill a clutch is what I'm forced to drive daily
Old Sep 15, 2014 | 08:52 AM
telum01's Avatar
Quick question - have you done the clutch relearn process lately?
Old Sep 15, 2014 | 09:13 AM
karlfranz's Avatar
You need to find another dealership. Mine usually charges about $3500-4000 US for a clutch replacement. $9K sounds outrageous.
Old Sep 15, 2014 | 09:14 AM
dmose's Avatar
I learn it once every-time I start the car, but I have never done the 3-4 times start/stop procedure before..
Old Sep 15, 2014 | 09:17 AM
dmose's Avatar
Tell me about it... but in the GTA toronto there is only one and can't find any good independent shops
Old Sep 15, 2014 | 09:19 AM
telum01's Avatar
We've got a few Toronto-based members on here, maybe one of them can point you to a better option.
Old Sep 15, 2014 | 09:53 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
The local NJ shop quoted me $6.2k USD for a clutch change.
The local indie ferrari shop quoted me a range from $4.5K - $6k.
A friend who runs a race shop and does maintenance for the local exotic rental place quoted me $1.8k in labor.
Old Sep 15, 2014 | 12:25 PM
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
That sounds like the clutch gone. Similar behavior to mine. 2 weeks later, it left me stranded (the car won't even start the engine). Change it soon unless you like having your car towed.
My clutch was ~4$k from an indy.
Old Sep 15, 2014 | 02:30 PM
deckman's Avatar
Does anyone know how many shop hours there are for this job? What is involved in the job that drives the labor so high?
Old Sep 15, 2014 | 02:55 PM
Tron's Avatar
Tron is infamous around these parts
Hey dmose, I am new to the form and AM as well but here is a couple of indy shops ppl have been posting about for our cars. I haven't tried any yet but have to do my annual service soon.
http://www.samsgarage.aaro.ca/
http://www.euautowerks.com/
http://speedstar.com/euro/
Old Sep 15, 2014 | 03:16 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
You need to first remove the transaxle, then the torque tube assembly to finally reach the clutch...
I don't know the precise hours involved, but there is a lot of "labor" involved to reach the clutch and flywheel assembly, which is why the cost is high.
The torque tube design is essentially a "fixed" drive line vs. the more common "open" (hotchkiss) drive line (for rear wheel drive vehicles).
http://en.wikipedia.org/wiki/Torque_tube
Old Sep 16, 2014 | 08:01 AM
dmose's Avatar
So an update..
I managed to get the car to dealer its 1st to 2nd was super rough and stalled at one point while driving. I had to restart a few times just to get it into first.
Anyhow, they came back and quoted $6700 CAD for parts + 16 hour labor..not that bad
Old Sep 16, 2014 | 12:10 PM
J doubleU's Avatar
Not that bad? Dealer here in California was $5100 (P/L)
Old Sep 18, 2014 | 09:02 AM
deckman's Avatar
Would still like to know what book rate is for labor. Prices are all over the map for what should be a known R&R.
I come from Porsches where labor rates aren't cheap but compared to this job they are. For the rates talked about here your can drop and replace a Porsche motor. The reason I ask is I am considering getting a used Vantage and will only consider a manual. Clutch replacement is a cost of ownership. Is everything else just as bad? I just figured, how much worse could it be than a pcar?
