Aston Martin DB7 Volante. Window problem! Help?
Hello.
I'm an owner of an Aston Martin DB7 Volante.
I've got a problem with my windows, i've changed both window ecu's and both window motors.
I've tried several times to do the reset memory function on the ecu's.
When I open the doors, hold the door latch the window wont go down 15mm. But when I open the door and it looses "contact" with the chassis the window rolls all the way down to the down position. And when I close the door it stays down. So I have to go into the car and take on the ignition again and roll it all the way up. And when I open the door again to go out of the car it rolls all the way down again.
So my windows stays open all the time. I've had this problem for 2 years now! And Im getting frustrated as hell!
Hope someone can help me out. I'm an car mechanic, but this window problem is so annoying i can't figure the problem out!
