Mounting clear tail lights on an 09 V8 Vantage
Old 01-22-2015, 09:31 AM
Irish07@VelocityAP's Avatar
Originally Posted by Bleen
Interesting. I have bought a bolt adapter kit from the seller (the bits website), they say you need it. Unsure how it's gonna pan out. I brought the tail light to work today, gonna see if they have something that would fit in the fabrication area.
Ok, well in that bolt kit you should have a billet bolt that is about 4-6mm threads on 1 side and about 8-10mm on the other..should have 2 of these funny bolts. Thread the small end into the insert on your clear lights..then just use the lock washer and nut from your old lights.
If this isn't to clear, take a pic of your bolt kit layed out, I'll point out what to use..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old 01-22-2015, 11:39 AM
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
Thanks! As an update: it's a 6mm thread. I got a long screw with the same thread and cut the head off. It ended up being almost the same length by chance. I also got a nylock nut to secure it, in case the bolt kit from Aston doesn't work. I should now have all I need to tackle this project.
I will be taking pictures/notes to make a more comprehensive DIY.
I wonder how the seal kit will play into this, there aren't any instructions on what to do with those.
Old 01-24-2015, 04:43 PM
Bleen's Avatar
Here's a writeup of the procedure.
All the stuff I got from astonmartinbits.
2 seal packs, 1 bolt pack, 2 trunk struts (mine were pretty much dead, and you need to keep the trunk open for most of the procedure), 1 tail light (I had one already), and the CHMSL. I also purchased automotive tape from Autozone.
The adjusters. You only need these if you bought a taillight that has a hole instead of a stud sticking out. I had fabricated a stud but didn't need it in the end because I had the adjusters.
You need to remove these metal domes inside the trunk to reach the tail light bolts. One side of the car has 3, the other one has 2. To reach the 3rd bolt on that side, just open the side panel by pulling the strap.
You can see the adjuster on the left.
These just unscrew with your hand.
Unscrew the nut. I used pliers, you can use a wrench. Careful not to lose the washer! There's one for every adjuster.
After you undo all 3 adjuster's nuts, the tail light just pulls out. The cable is pretty short but you can gently pull it out a bit. The rubber sleeve pops out. The connector is hard to pull out, you can see you need to pull out the red end to the side. I suggest having somebody hold the light while you do this.
This is where the seals are. I highly recommend replacing these! They're cheap and will protect your trunk from water ingress.
- Will continue in next post -
Old 01-24-2015, 04:53 PM
Bleen's Avatar
The back side of the seal. The silver part is just a washer. There might be some light glue holding these in place, they will just pop out by pulling gently.
THIS is why you need to replace them! This is what they look like after you take them out. Thin and bent out of shape.
You can just slide the washers inside the carpet if you're too lazy to undo the top. This is actually a pretty tough maneuver.
This is what the adjusters look like when connected to the original lights. I grabbed a measuring tape and measured all the distances, so I could replicate them with the new ones.
This is the hole in one of the new lights. Only one of the clears had a hole. This is apparently not a defect, just different models.
This is where the new adjusters go. Gets rid of one part.
After a lot of adjusting, the lights were on! Still needed to do the CHMSL and the inserts.
- To be continued -
Old 01-24-2015, 04:58 PM
Bleen's Avatar
For the CHMSL, you need to first undo this bolt.
Then grab a trim removal tool and just pull out HARD. You need to remove at least the bottom 4 of these. I'd suggest buying some new ones to replace them, as they will be pretty banged up.
Remove the plastic pin and pull out the metal cord from the handle. Then you can pull the carpet liner out to get access to the CHMSL area.
Your nuts will look different! I had replaced mine previously with nyloc nuts since my car was missing one. Make sure not to lose the washers. You only need to undo two.
Pull the metal part out completely to disconnect the light.
Yet another example on how seals wear out. Take this into account when installing the new light, since it won't line up unless you put a lot of force on the nuts.
- To be continued -
Old 01-24-2015, 05:04 PM
Bleen's Avatar
Trim removal tools next to the recently unglued insert. These were really easy! I was initially worried but you just need to insert one of these tools between the tail light and the insert, the gradually destroy the tape. The insert is malleable and will deform a bit.
Goodbye, red light!
Clean everything up. I used WD-40 first, then quick detailer. I then left everything to dry for a few minutes.
I messed up with the tape by buying it too thick, so I cut it up. Remember to clean all surfaces and tape up as close as you can to the original pattern.
Done! Beautiful, it really fits the Tungsten!
Old 01-24-2015, 05:48 PM
speedracer800's Avatar
speedracer800 is a jewel in the roughspeedracer800 is a jewel in the roughspeedracer800 is a jewel in the rough
Nice job! Looks great.. Congrats!
Old 01-25-2015, 01:07 PM
deckman's Avatar
Nice DIY post!! The AM forum needs more like this 👏
Old 01-25-2015, 03:00 PM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Great DIY and thanks for putting all the pictures into the write up!
Old 01-25-2015, 08:37 PM
BeenThere's Avatar
BeenThere is on a distinguished road
Beautiful. Nice work, appreciate the details and tips.
Old 01-25-2015, 10:36 PM
V12Vin's Avatar
V12Vin is on a distinguished road
Good DIY! thanks for posting.
Old 05-16-2015, 07:33 PM
Jeff1smith's Avatar
Jeff1smith is on a distinguished road
Changing red for clear. One light came with the removeable brass bolt the other without. Anyone have just the one leftover?
Old 08-03-2015, 04:35 PM
goto35's Avatar
goto35 will become famous soon enoughgoto35 will become famous soon enough
Bleen. Do you have the part number for the seal kit?
Old 08-03-2015, 08:21 PM
Bleen's Avatar
I don't, sorry... they didn't come with any I believe... but... look for
"REAR LIGHT SEAL KIT RED LAMPS & CLEAR LIGHTS" on the astonmartinbits website. Unsure if I can post a link.
Old 08-07-2015, 11:04 AM
goto35's Avatar
Hey Bleen,
That tail lamp adjuster did 2 of them come in that 1 part number? Or so i need to order 2 quantity? Velocity AP has them for $42 but im not sure if it includes 2 of them or just 1.
Quick Reply: Mounting clear tail lights on an 09 V8 Vantage
