Convertible Top Malfunction
Old Sep 11, 2016 | 10:10 AM
  #31
23546ghhga99's Avatar
23546ghhga99 is infamous around these parts
https://vimeo.com/182218373?utm_sour...campaign=29220
This is a very good video that describes a solution to a problem that is different than the first described roof malfunction problem in this forum. The roof malfunction described in this forum disrupted many of the sensing items listed in the graph in a previous posting (Speedometer, boot latch, window closure, instrument lights, etc...). Because of these problems, replacing the CRM is prudent.
Thanks, I will keep this video in my archives as it describes a different problem.
Thanks.
Old Sep 11, 2016 | 10:59 AM
  #32
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Originally Posted by dallasbaker
I have an 06' Volante and the top suddenly stopped working.
It is in the closed position and when I activate the lower button, the front unlatches and opens a few inches, and the windows lower. That is where it all stops. The rear tension bow does not rise. I hear no pumps running. It will close back and latch with no problems. I have checked the boot fusebox and all appear ok. Does anyone know where the pump relay is located or have any other ideas?
It is not giving any error codes.
video i posted help fix problem described by dallasbaker or at least I had same problem.
If CRM is problem then Instrument cluster goes crazy, nothing display, 0 RPM, O MPH speed, I had that probem too. You can confirm CRM is the problem by removing CRM and then starting the car. Display will come back to life, but roof won't work.
Old Jun 4, 2017 | 03:29 AM
  #33
lostinla's Avatar
lostinla is infamous around these parts
Convertible Top Manual for DB9?
Originally Posted by zuman
You noted that you have the convertible top manual. I assume you mean the "Technical Guide - Convertible Roof System - Electronics Training Programme" downloaded from the AM tech site? If not, I have that...
Sorry to bring back an old thread, but is there any chance you (or any other folks) would be willing to send me a copy of that manual?
I have a 2005 shop manual PDF, but it's often inaccurate and is definitely a bit light when it comes to the top. There are a few "image to come" placeholders, oddly enough.
Thanks in advance,
David
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
simoncpw
Sep 8, 2015 10:55 PM
ECS Tuning - BMW
Sep 4, 2015 01:23 PM
zuman
Sep 3, 2015 08:27 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
