One of the main causes of engine stalls
Old Apr 1, 2016 | 02:33 PM
  #31
adnanm3's Avatar
adnanm3 is infamous around these parts
Im wondering if I am having this issue myself - as I am experiencing stalls worse when my gas tank is full. However, I am throwing codes for my throttle body.
I'm having a bit of trouble assessing the issue as my gas tank is nearly full at this time. I see a larger rubber pipe down inside the gas tank - I tried taking a picture of it. Is this the way it is supposed to appear?
Old Apr 1, 2016 | 03:02 PM
  #32
telum01's Avatar
The hose that usually causes the problem is at the top of the fuel tank. Your pics are looking down toward the bottom of the tank - you need to look inside the tank but toward the top/"ceiling" within it.
Old Apr 2, 2016 | 08:38 PM
  #33
adnanm3's Avatar
Thanks for letting me know, I was clearly going about it wrong. I do not have an issue with this hose.
For anyone else that wants to check, one easy way to take a look is by using your cell phone camera - and pointing it upside down into the gas tank. I got a good view this way.
Old Jun 2, 2016 | 08:15 PM
  #34
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Originally Posted by mrgylex
Same exact piece (part numbers are identical). Why the AM dealership has to do a special order of this part and quote me $236 is highway robbery when the same part at the Jaguar/LR dealership is $36.
@Irish--I installed the part and the PCV valve is making a loud buzzing noise--sounds like a remote control plane is inside the engine bay, I can feel the noise coming from the valve, when I pinch the flex hose, the noise goes away.
What's going on here?
Is this for db9 or vantage?
Jul 29, 2019 11:13 AM
midwestamv8
Audi
Sep 9, 2015 11:53 AM
away
Sep 4, 2015 12:30 PM
vr6tee
Aug 29, 2015 03:52 AM
