08 vantage roadster. Top wont close can hear motor but not moving. No malfunctions
Old Mar 16, 2015 | 08:09 AM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
The top few days ago seems like it was opening and closing a bit slower than usual. Today I opened the top (again seemed slower than usual plus noise from motor was bit strange) now the top won't close.
I can hear the motor work however the tanneau cover barely moves and nothing happen. The cover moves maybe 1 inch and that's it.
What can it be? Not the module right? Maybe the fluid or maybe the actual motor it self?
Do you guys this this will be an expensive fix?
I guess I will need to go to dealer now...
Old Mar 16, 2015 | 09:19 AM
telum01's Avatar
Module is the first place to look, and if that's okay then it might be something mechanical. Motor is spinning but not engaging something?
Old Mar 16, 2015 | 12:56 PM
goto35's Avatar
Yes it seems the motor is spinning but doesnt have enough juice in there to actually move it up! It may be the motor, mechanical, but i dont think its the module.
Anyone have recommendations as to where i can take this in Los Angeles?
Old Mar 16, 2015 | 08:09 PM
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
John at New Tickford. He's down in the San Diego area but I won't take my car anywhere else.
Old Mar 19, 2015 | 07:50 AM
Irish07@VelocityAP's Avatar
If you hear the motor and only little to some movement occur on tonneau and top.. I'd shoot for a possible hydraulic leak with the lines through the convertible top skeleton frame.. The lines have been known to get pinched and leak out. If your able to lift the top out of the tonneau manually, have a look inside the tonneau area for any wet areas.. Should be bone dry
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Mar 23, 2015 | 07:55 PM
goto35's Avatar
Took it to Beverly Hills Aston (they have been absolutely great with everything!)
It turns out to be a hydraulic leak just like irish said. I wonder if this is common.
Old Mar 23, 2015 | 10:51 PM
Bleen's Avatar
Old Mar 24, 2015 | 07:04 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Not currently common
Though as these get older I suspect more common!
Old Jan 1, 2017 | 10:12 AM
Senatorblutarsky's Avatar
Senatorblutarsky is infamous around these partsSenatorblutarsky is infamous around these parts
How Do I access the skeleton top on my roadster?
I have a leak in the hydraulic line on my roadster. I would like to find and fix it myself. I have already paid the dealer $3,000 trying to fix it and that's all they are going to get from me. Any advice on how to access the hydraulic lines is much appreciated!
Thanks!
Old Jan 1, 2017 | 10:21 AM
Thanks!
There's really no advise, just open tonneau cover and find the one that's leaking. Then remove any parts you need for access to run a new pipe from pump(RHS tonneau area if also a V8V roadster) all the way to the bow with the leaking pipe.
Have you pin-pointed the one that's leaking?
Old Jan 1, 2017 | 12:50 PM
I have not pinpointed which one is leaking. I do know that two years ago when I had the car serviced the shop found hydraulic fluid in the well where the top tucks in when opened.
mikerosi
Dec 6, 2018 06:23 PM
4ocious
Sep 13, 2015 05:00 PM
orbelo
Aug 30, 2015 12:26 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
