05 DB9 subwoofer wiring
Old May 19, 2015 | 07:11 PM
corveight's Avatar
corveight is infamous around these parts
I have 5 wires going to the sub. Heavy gauge red and black. And 3 small red white and black. Does anyone know what the small 3 wires are for? It's a Lynn 950 watt system.
Old May 20, 2015 | 05:16 AM
J doubleU's Avatar
Manufacture specific from Linn that monitors driver movement and changes output at amplifier to keep the driver from under or overdrive to not allow distortion.
Old May 20, 2015 | 08:42 AM
corveight's Avatar
Is it possible to use an aftermarket sub with out the driver monitor? If I try one is it possible to harm the Amp? I am not pleased with the distortion so I'm looking for a solution. After hearing and seeing many posts critical of the Lynn performance I am looking for alternatives.
Old May 20, 2015 | 04:56 PM
J doubleU's Avatar
You could use any sub driver with the Linn amplifier, you just delete the additional 3 small wires. You will not hurt the amplifier it's just their add-on for "extra special tuning". You can add more fiber stuffing as it is a sealed unit. Make sure the cheap foam on the metal speaker grill is removed also. The Linn sub is a really nice driver so I would recommend you check and seal the box and mounting before changing it out.
Old May 21, 2015 | 04:25 AM
corveight's Avatar
I have the old aluminum support for the sub wide open all around except for the center trim covering it. Any recommendations for sealing material? I really appreciate your help.
Old May 21, 2015 | 04:38 PM
J doubleU's Avatar
100% silicone and let it cure before 're-assembly of the driver.
KOCF
Jul 18, 2019 03:09 AM
airbusdrvr
Dec 27, 2015 07:43 PM
Wildcat1212
Sep 24, 2015 08:27 PM
Stuart@VelocityAP
Sep 23, 2015 05:30 PM
