Valentine One hardwire in 2014 Vantage
Old May 20, 2015 | 07:03 PM
chamstra's Avatar
chamstra is infamous around these parts
I am looking for information on hardwiring in a Valentine One in a 2014 Vantage. Specifically around pulling the required interior trim (A-Pillar, and ...) as well as the best connection point - fuse box in the passenger footwell???
I have search for info, but have not found anything that helps.
Thanks for your help!
Old May 20, 2015 | 08:25 PM
karlfranz's Avatar
First of all, it would be nice to introduce yourself prior to asking questions.
Are you an owner or an installer?
The best and easiest way to connect the Valentine One is to purchase the optional Savvy module. This device plugs into the OBD-II port on the car and allows it to automatically power the detector only when the engine is on. There is no hardwiring whatsoever. It is completely plug and play.
Even better, the Savvy module interfaces with the car's ECU and can read vehicle speed. It has a dial that allows you to set a speed below which all alerts play at the muted volume. I have mine set to 35mph, because I don't want to be bothered for anything below those speeds.
I highly recommend it.
Cheers.
Old May 21, 2015 | 11:02 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
The TPMS box in the passenger footwell has switched power and a ground. I spliced in there. Didn't need to go all the way into the fuse box. Not sure if newer cars still have that external SmartTire setup.
The wire tucked in cleanly behind the map lights and across the header and down the a-pillar on the passenger side without removing either. I was replacing the leather on the passenger panel by the windshield at the same time so I did need to remove all that to get the wire cleanly down into the footwell. There is a sticky here for 'how do I remove this panel.'. If you want it to look perfect you will probably wind up in that direction to at least get access.
Not particularly fun work, but pretty straight forward.
doughsun
Jan 31, 2016 04:22 PM
XLR82XS
Oct 5, 2015 07:02 AM
Vic55
Sep 14, 2015 09:42 AM
markj
Sep 11, 2015 11:29 AM
