DBS owners - anyone know where this wire goes?
Old Jun 8, 2015 | 04:41 PM
wysoseereeus's Avatar
wysoseereeus is just really nicewysoseereeus is just really nicewysoseereeus is just really nicewysoseereeus is just really nice
Accidentally yanked a wire under the glove box loose while wiring up some cameras. Seems to be a single, black ground wire of some sort enclosed in a plastic loom.
The end that I need to reconnect is wrapped up in electrical tape. (I peeled back the tape, and it looks like a black/greyish spade connector.)
One end terminates in the fuse box, the loom runs along the bottom of the fuse box, up the side, and out of the fuse box, and then connects somewhere. (??)
I've attached photos. The green line shows the route of the loom.
Reaching out to fellow owners to see if someone has a moment to snap a photo of where this wire terminates.
(Btw, there should be no need to open up the fuse box. I believe there's only one skinny plastic loom coming out the top.)
Any help would be much appreciated.
Name:	wire - disconnected end.JPG
ID:	421747   Click image for larger version
Name:	wire - another view.JPG
ID:	421748   Click image for larger version
Name:	wire - fusebox route.JPG
Old Jun 11, 2015 | 07:47 PM
To see the loom I'm referring to, you'd have to pull back the top of the floormat (secured by double-sided tape) and expose the top of the fusebox.
The loom comes out of the top right of the fuse box and yours probably goes directly behind the right hand side trim, so you'll probably have to pull back this trim a bit to see the loom and then to find out where the loom goes to.
My photos show the fusebox cover plate removed and a bunch of extra wires from my dashcam, so it definitely has a mess of stuff going on compared to yours.
I've added a couple more pictures to the post to make things a little more clear.
Adding a couple more photos
Old Jun 18, 2015 | 09:27 PM
Old Jun 19, 2015 | 03:50 AM
rscultho's Avatar
rscultho is infamous around these parts
So u r wanting to know where it connects near the fuse box?
I will look at mine today and see if it is visible...
Old Jun 19, 2015 | 05:02 AM
rscultho's Avatar
Item Part Number Description Quantity Remarks 1 8D33-7E443-AB Harness, MANUAL transmission 1 - 2 8D33-14A227-AB Harness, boot lid, COUPE 1 - 3 8D33-15B484-AB Harness, rear bumper, PDC 1 -
Old Jun 19, 2015 | 07:35 AM
Originally Posted by rscultho
So u r wanting to know where it connects near the fuse box? I will look at mine today and see if it is visible...
I know where it connects INSIDE the cabin fuse box. It's the opposite end that got disconnected that I'd like to reconnect.
Best I can tell it connects to something behind the right hand trim under the glovebox.
Old Jun 19, 2015 | 08:06 AM
rscultho's Avatar
Item Part Number Description Quantity Remarks 1 8D33-14401-GD Harness assy, facia, MANUAL 1 RHD - AG43-14K024-AB Harness assy, facia, MANUAL, B and O 1 RHD 9.5MY - 8D33-14401-HD Harness assy, facia, MANUAL 1 LHD - AG43-14401-AB Harness assy, facia, MANUAL, B and O 1 LHD 9.5MY 2 8D33-14B079-AF Harness assy, console panel 1 - - 9G43-14B079-DC Harness assy, console panel, MANUAL, B and O 1 9.5MY - 9G43-14B079-CC Harness assy, console panel, AUTO, B and O 1 9.5MY 3 8D33-9137-BA Harness assy, PATS link 1 - 4 9D33-14N003-AA Inline bracket, IP, RHS B and O 1 9.5MY 5 9D33-14N003-BA Inline bracket, IP, LHS B and O 1 9.5MY - 4G43-18C951-HB Harness assy, MOST 1 -
Old Jun 19, 2015 | 09:27 AM
Thank you, though I'm not quite clear what I'm supposed to be looking for based on those parts manual pages. They appear to show a part in the boot area. The wire I'm trying to reconnect is in the cabin area in the vicinity of the glove box. If you can shed some more light here, I'd appreciate it.
Old Jun 19, 2015 | 09:31 AM
Okay, I see that the second image shows a part in the cabin area. Thanks again. Though I'm still not quite clear how to decipher it...
Old Jun 19, 2015 | 09:53 AM
rscultho's Avatar
Given the area it is associated with, and the color, it is probably connected to the a light of some kind - maybe your glove compartment light, or something similar...
Old Jun 22, 2015 | 10:13 AM
Irish07@VelocityAP's Avatar
Does the tape cover a connector? Whats the connector look like, take a pic of it and I'm sure I can help figure it out..
Old Jun 22, 2015 | 10:28 AM
Thanks, Irish07. Yes, here are a couple pics of the connector under the tape.
Old Jun 22, 2015 | 10:37 AM
That does not look like anything original, actually I'm pretty sure it's 100% not original. With that end it looks like someone has made an antenna and routed it through the dash. Even the wire loom used doesn't look like it was routed by the factory, really looks aftermarket. I can see you have something aftermarket splices into the CEM, could it possible be relates to what ever is there, like a audio transmitter or remote start/alarm module?
Old Jun 22, 2015 | 10:41 AM
anton28's Avatar
anton28 has a spectacular aura aboutanton28 has a spectacular aura about
Isn't that an aftermarket connector that plugs in to the fuse box to splice power from another fuse for an aftermarket accessory?
Old Jun 22, 2015 | 10:44 AM
Could be used for that, but doesn't piggy back off the fuse, you would have to remove a fuse and plug in this fitting..which would be non fused now unless it is at the other end and also the wire isn't red to show its carrying power
