Washer Fluid Leak
Old Jun 9, 2015 | 07:29 PM
kaj's Avatar
kaj
kaj is infamous around these parts
Washer Fluid Leak
My 2012.25 Vantage ran out of washer fluid. Filled it up with a full bottle of fluid and it dumped out all over the driveway floor. Can't tell where the leak is originating from, looking underneath it's somewhere on the passenger side (same side as the filler and, I'm assuming, reservoir). Anyone else had this happen?
Old Jun 9, 2015 | 10:01 PM
karlfranz's Avatar
Sounds like one of the hoses going from the reservoir may have come loose. If your car is no longer under warranty, remove the front passenger wheel and wheel liner. The reservoir is on the trailing edge of the wheel well ahead of the passenger door.
Old Jun 10, 2015 | 08:46 AM
telum01's Avatar
Happened on mine, too. I only keep the reservoir about half full so it doesn't affect me, but if I topped it off it'd leak. Found out when a tire shop did a complimentary top-off and made a small mess on their floor lol.
Old Jun 10, 2015 | 10:52 AM
bubba's Avatar
bubba is infamous around these parts
That happened to me too, turned out the reservoir had cracked. Believe it or not, a new reservoir is $700(ish)! - I'm long out of warranty - My local dealer's very skilled mechanic simply epoxied the crack - all is well a year on.
Old Jun 10, 2015 | 08:45 PM
midwestamv8's Avatar
midwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud of
Happened to me, too. Aston was kind enough to repair the leak under CPO warranty.
cockneymike
Oct 22, 2015 06:00 PM
laz74
Oct 2, 2015 06:08 AM
MrMiggy
Sep 14, 2015 02:18 PM
sparks
Sep 8, 2015 03:03 PM
