Common Problems
Old Jun 10, 2015 | 08:52 AM
telum01's Avatar
Common Problems
NOTE: This is a workspace thread for gathering/organizing info that will become a reference. It'll change a lot and be edited often, so don't mind the mess!
I'm going to start putting together info for the FAQ about common problems. Two of them came up this morning (CEL from a possibly bad thermostat, and leaky windshield wiper reservoir), and I realized the only thing we have in the FAQ is:
Recalls and Known Major Issues:
In general these are good once fixed and won't reoccur, though that repair can be costly.
V8 Vantage timing cover gasket (expensive)
V8 Vantage door lock mechanisms (expensive)
Navigation screen gears (inexpensive)
Fuel vapor recirculation hose (inexpensive)
Leaking windshield wiper fluid reservoir (inexpensive)
And the last one I added this morning. So I want to compile some info to address those specifically. If anyone has anything to add to that list, or some links to threads that specifically cover those, please post them up!
I'll be adding notes about them, fixes, cost estimates, DIYs, links to other info, etc etc, so anything and everything known about the issues would be appreciated.
Thanks!
EDIT: Started taking notes, this is a work in progress! The below are notes will eventually become a new thread, stickied, and ref'd in the FAQ
Need link
Need link
Need link
Fix pic in link
Need link
05-06 DB9 TT2 transmission cooler hose connections hadcorrosion/leak issues. About $2K to fix at the dealer. Probably not many leftthat haven't been done. Cooler is below the front bumper behind the grille,connections are visible.
Need link
Add the "stuck gas cap, damn it, why won't it open?".
Need info, link
Leaky gas cap, cost
Need info, link
TPMS Sensors/batteries
Need info, link
Thermostat failures, replacement, parts, and CEL from running rich
Need info, links
As with any new car from a small manufacturer, Aston models enduresome growing pains. While these problems were generally fixed over time, theycan be commonplace in the first few years of production. When buying a used car, check to see if anyof these problems have been resolved on the cars you’re looking at. Early model year Aston can be bought for afraction of their new-car MSRP. But ifany of these problems persist, that low entry price can backfire and you’ll bestuck with some painful repairs.
V8 Vantage Timing Cover Gasket
Early production year V8 Vantages often suffer from a slight oilleak from the timing cover gasket. Arevised gasket fixes this problem. The gasket itself is very inexpensive. However, extensive labor is required toreplace the faulty gasket with the new one. This job can cost upwards of $5000. Once completed, the problem should not reoccur. A half-way solution involves much less laborand costs less than $2000, but does not guarantee that the problem will notreturn.
V8 Vantage Door Lock Mechanisms
The early V8 Vantage door lock mechanisms can fail, leading to embarrassingmoments of having to use your key to manually lock and unlock the doors. Notvery fashionable for a high-end exotic like an Aston Martin, is it?
Navigation Screen Gears
Aston Martin uses a mechanized screen for its navigationsystem. Unfortunately, the gears aremade of plastic and can chew themselves up, often without warning. Aston sells a repair kit with all partsnecessary to fix the gears. The job canbe done for less than $200.
Fuel Vapor Recirculation Hose
This is one of the more terrifying problems to encounter as itstalls your engine and leaves you without engine, brakes, or steering. The stall usually happens at low speeds whenalready coming to a stop, so hopefully you’ll be in an easily-controllable situation. Information about this problem can be foundhere:
https://www.6speedonline.com/forums/aston-martin/359095-one-main-causes-engine-stalls.html
Leaking Windshield Washer Fluid Reservoir
The windshield washer fluid reservoir can crack, causing it toleak washer fluid. It’s possible thatyou never notice the problem, as the fluid level may be below the crack. Keeping the fluid no more than halfway full isa way to effectively ignore the problem. Fixing it can be done two ways: Either replace the reservoir (which cancost several hundred dollars!) or epoxy the crack of the original. KarlFranz explains where the reservoir is:
“If your car is no longer under warranty, remove the frontpassenger wheel and wheel liner. The reservoir is on the trailing edge of thewheel well ahead of the passenger door.”
https://www.6speedonline.com/forums/aston-martin/366596-washer-fluid-leak.html
DB9 TT2 Transmission Cooler Hose Failures
Earlier model year DB9s (generally ’05-06) experienced problemswith their transmission cooler hoses. The connections would corrode and leak over time. These can be replaced by the dealership forabout $2000.
Tail light condensation
http://www.pistonheads.com/gassing/t...l+light+custer+
Old Jun 10, 2015 | 10:22 AM
telum01's Avatar
Adding DB9 oil dipstick
Any other DB9 issues to include? I'm not terribly familiar with them so I'll need help there.
Old Jun 10, 2015 | 11:05 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Early (2005, 2006?) DB9 TT2 transmission cooler hose connections had corrosion/leak issues. About $2K to fix at the dealer. Probably not many left that haven't been done. Cooler is below the front bumper behind the grille, connections are visible.
Old Jun 10, 2015 | 11:33 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Old Jun 10, 2015 | 11:47 AM
telum01's Avatar
Rock on, thanks guys
Old Jun 10, 2015 | 11:55 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Maybe the "DSC service required" item for the v8 as well, had that happened to me but like most results I've found online, goes away by itself:
https://www.6speedonline.com/forums/...-required.html
Old Jun 10, 2015 | 12:04 PM
telum01's Avatar
Good link, the TPMS thing with it!
Old Jun 10, 2015 | 12:49 PM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
Tail lamp assy
- moisture in assy - where to drill holes to help dry out
- can lead to bad circuit board
- can also impact front turn signal operation
Clutch
- types to replace with
- dealer, do it yourself, independent options
Shifter cable
- how to adjust and or replace (I'll be needing this)
Brakes
- include info on factory bulletin on quiet shims and grease to eliminate squeal
exterior trim fixes
door, hood (aka bonnet), and rear hatch struts
Old Jun 10, 2015 | 01:07 PM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
Headlight Assy
- moisture in assy. think one member had a detailed diy on venting mod
Leather Shrinkage
- quite a few discussions on various pieces/panels
Passenger SRS Light
- most likely the passenger seat needs to be moving forward
Symptoms after a flat battery and reset procedures
- windows, mirrors and seats
Old Jun 10, 2015 | 01:12 PM
telum01's Avatar
What did I get myself into
Old Jun 10, 2015 | 01:29 PM
More of a long term project. If each has a section we can add to it as needed
Old Jun 10, 2015 | 11:27 PM
karlfranz's Avatar
Here's the beginning of my list contribution:
Commonly Reported Problems
Body
  • Corrosion near side strakes
  • Corrosion near door handles
  • rear corner of door window strikes rear quarter window
  • convertible roof scuffing and wear near hinges
  • Windshield washer reservoir and motor assembly leaks
  • water leaks in boot area
Electrical
  • quiescent battery drain
  • gremlins when battery low
  • battery removal when battery dead
  • power door lock failure
  • side window auto-lower not working
  • “Passenger Airbag Off. Ser. Urgent” message on DIM error due to seat recline
  • limit programming erased causing restricted power seat travel
Lighting
  • headlight condensation
  • headlight LED failure
  • taillight condensation
  • taillight LED failure
  • headlight washer cover falling off
Engine
  • timing cover leak
  • valve clicking/ticking sound
  • improper oil level
  • groaning noise from older metal Oil Pressure Relief Valve during cold engine start and warm-up
  • belt pulley squeak
Clutch
  • premature clutch wear
  • clutch learn not performed automatically on older cars
  • creep mode causes wear
Transmission & Driveline
  • difficulty is selecting 1st and 2nd gears after cold engine starts
  • clunk sound when releasing clutch pedal
  • rattling sound when starting to move forward
  • sport shift hydraulic leak prevents gears from being selected
  • Rear halfshaft and hub clunking noise
  • Shifter cables become loose or disconnected
Brakes
  • mouse squeak when turning left at slow to moderate speed
  • high pitched squeal when brakes applied
Wheels & Tires
  • Tire pressure monitor sensor battery failure
Suspension
  • DSC Service Required message on driver information module
  • power steering pump squeak when turning wheel
Fuel System
  • Stuck fuel filler door
  • cracked plastic on fuel cap
  • evaporative leak on fuel cap
  • cracked fuel vapor recirc hose in fuel tank
Interior Trim
  • leather shrinkage on trim panels
  • leather squeaks
  • squeaking near steering wheel
  • ECU dock halves falling out (or in)
Climate Control
  • Incorrect ambient temp display
Entertainment & Convenience Systems
  • scratches on ICE display
  • wear scratches on selection buttons
  • Mobile phone Bluetooth pairing problems
Navigation System
  • Park assist chime stuck on (sensor dirty)
  • outdated system maps
  • stripped gears in screen raise mechanism
Alarm System
  • Alarm Service required (battery in alarm module dead)
Exterior Trim
  • water stains on metal grille bars
  • grille plastic brackets cracking
  • metal grille bars falling off
Old Jun 11, 2015 | 10:10 AM
telum01's Avatar
Thank you, sir
Old Jun 11, 2015 | 10:56 AM
telum01's Avatar
Got started on this in an external Word .doc
Here's part of a section to show the format I'm using, input appreciated. (These aren't finished, either.)
MECHANICAL
Engine
Timing Cover Oil Leak
Early MY V8 Vantages suffered from a slight oil leak fromthe timing cover gasket. The leak ismanageable but should be fixed. AMLupdated the gasket design and it solves the problem. While the gasket itself is inexpensive, therepair requires extensive labor and the job can total as much as $5000. A half-way solution can be performed for lessthan half of the cost, but does not guarantee the problem will not return.
FEAD Belt Squeak
The front end accessory drive (FEAD) belt can make asqueaking noise on early MY V8 Vantages. The problem is not the belt itself,but rather the idler pulley. Theoriginal design had a wall on the rear side of the pulley, but not on thefront. The updated pulley has walls onthe front and back. The new pulley is adirect replacement for the old on, but requires an updated belt to fit the newdesign.
UpdatedIdler Pulley 9G33-19A216-AA
Updated FEAD Belt 9G33-8620-AA
Fuel System
The fuel vapor recirculation hose is found inside the gastank. Its job is to vent excess fuelvapor out of the gas tank and into the intake manifold, where it can enter theengine to be burned off through the normal combustion cycle. This hose has a tendency to tear, at whichpoint it sucks up fuel and dumps it into the engine, causing it to stall. When the engine stalls, engine power,steering, and brakes are all lost until the engine is restarted.
The problem with the hose is caused by its length. The hose is too long, and droops between thevapor valve where it starts and the point at which it exits the fuel tank. The droop causes chafing inside of the hoseagainst the tip of the valve hose nipple. Over time, this chafing will wear through the hose, causing it to splitopen, and allowing it to suck up fuel.
A DIY repair guide can be found here:
Old Jun 11, 2015 | 11:02 AM
karlfranz's Avatar
You might want to look at whether 6 speed has the ability to create a wiki.
