Help! My 2007 Roadster always thinks it is in reverse?
Old 07-05-2015, 01:33 PM
Senatorblutarsky's Avatar
Senatorblutarsky will become famous soon enoughSenatorblutarsky will become famous soon enough
Question Help! My 2007 Roadster always thinks it is in reverse?
The red 'R' in the middle of the dash is almost always on, sometimes it blinks. The reverse chime sounds and the reverse lights are on also. This happens whether I am actually in reverse or on the highway in 6th gear. Any ideas on what is wrong and how I can fix it? Any help is greatly appreciated.
Old 07-05-2015, 04:16 PM
J doubleU's Avatar
Reverse switch sticking, faulty. It's a 3 pedal car correct.
Old 07-05-2015, 05:52 PM
Yes, it is a 3 pedal car. Is the reverse switch easy to access?
Old 07-06-2015, 06:46 AM
HenryM's Avatar
HenryM is on a distinguished road
This happened on my 2007 V8 Vantage about 4 years into ownership. The problem is discussed on the AMOC forum (search the AMOC forum) and known by Aston. There is a sensor on the transmission that can overheat at high speeds (for me it was sustained speed at or above 80mph). I believe the fix was a spacer inserted to move the sensor further away and a new sensor. Mine was covered under extended warranty but I believe the cost wasn't much.
Henry
Old 07-07-2015, 05:07 AM
Thanks!
I assume the reverse switch must be in the gearbox with the shifter.
Old 07-07-2015, 05:40 AM
J doubleU's Avatar
Reverse switch is screwed in to transmission case at the upper right hand side. Depth of switch engagement needs checked on replacement. It may check ok with new switch. If not it will need increased/decreased adjustment. Not really a DIY job. You can also disconnect the switch to make sure it's the fault. Although you will be unsafe with no reverse light or park-aid if equipped.
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
jrblackbox
914/914-6
11-19-2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
RallyBird
10-07-2015 01:20 PM
Quick Reply: Help! My 2007 Roadster always thinks it is in reverse?
