Vantage V8S 2015
Old Jul 4, 2015 | 10:01 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Vantage V8S 2015
So I just poured my last bit of oil into this thirty beast. Right now I'm wondering where is all the oil going? Does this engine really burn THAT much oil?
Some technical discussion would be greatly appreciated.
Much thanks
Peace
TAC
Old Jul 4, 2015 | 10:08 PM
Speedraser's Avatar
Speedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond repute
Not very technical, but as a data point, I've never had to add oil to my '09 V8V.
Old Jul 4, 2015 | 10:11 PM
SandmanG500's Avatar
SandmanG500 is infamous around these parts
Much thanks
Peace
TAC
Did you track how many miles between interval when you have to replenish the oil?
Old Jul 4, 2015 | 10:21 PM
No, I have not. I generally check the oil level every 10 days, or each time that I fill the gas tank.
(just to add, I do drive aggressively)
Old Jul 4, 2015 | 10:27 PM
Start doing it tomorrow, guesstimate your oil consumption and divide over miles interval. Compare what you have to the acceptable oil consumption standard. The standard assumption of engine oil consumption is below 1 quart per 1000 miles.
Old Jul 5, 2015 | 12:00 AM
J doubleU's Avatar
At least you're keeping it on level. Your driving habits and monitoring it I do commend. I assume you are checking it at the same temperature, run time and procedure as indicated in the manual. I only ask cause I have found the levels change dependant on how it's checked even within a few minutes and cold, warm or hot.
Old Jul 6, 2015 | 05:42 PM
I only check the oil level in the morning, after it sits overnight.
Start up, run between 1500 and 2000 rpms for 20 secs. Wait 30 secs, and then check.
Old Jul 7, 2015 | 08:28 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Because it's a dry sump system, aren't you supposed to check it only when the car is off?
Old Jul 7, 2015 | 08:59 AM
Did I forget to say, "turn off the engine", and then wait thirty seconds before checking the level?
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
MJM911
New England
Oct 15, 2015 07:39 PM
XLR82XS
Oct 5, 2015 07:02 AM
007 Vantage
Sep 10, 2015 11:40 PM
midtownlandman
Sep 3, 2015 01:17 PM
