Vantage Nitron Adjustable Coilovers
Old Nov 7, 2016 | 12:54 PM
  #31
Montana107's Avatar
Montana107 is infamous around these parts
Originally Posted by cret
Montana107 - I thought Vanage GT4s were running on Nitron R1 for a while?
Cret - I am not sure - The guys at Nitron said something about they had a chance and just about became the AMR suspension of choice but "politics got in the way"... who knows... - but I can confirm AMR uses Bilstein as their "go to" and Koni for a lower tier solution - This is according to TRG, their US supplier -
Old Nov 7, 2016 | 01:14 PM
  #32
Montana107's Avatar
Originally Posted by spyder997s
Montana: your car looks amazing. Very nice stance and wheels!
Cret: The TRG Vantage GT4, which is North America's Aston Martin Racing team, uses Bilstein, and I can confirm what Montana said, they are expensive based on the quote I received from them as well.
I didn't think to inquire at Bamford, but that is a great option, especially since it is nicely priced.
It's too late for me though: I already have a set of kW coilovers waiting to be installed.
spyder997s - Thanks for the kind words! Please keep us posted on how the KW's perform.
I am going to add some spring rate to my solution and also soften up the front slightly to reduce understeer and see how things work (probably 625lb front and 725lb rear) - If I still have issues then I will most likely go the Bilstein route or do a custom set up with Motion Control Suspension (MCS) - This MCS solution could be a HOT set up if I spend some time with them but not sure how much work I want to put into this project...
Old Nov 7, 2016 | 01:28 PM
  #33
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
Any recommendation on sway bars? Did you upgrade those too?
Old Nov 9, 2016 | 04:17 AM
  #34
Montana107's Avatar
I have not done anything to the sway bars. You probably have more detail than me on this but aftermarket are rare to none. I have a S model so understand it might have a stiffer sway bars than the standard models - not sure - I was informed that the sway bars on the GT4 cars are the same as mine
I wish there was a reasonably affordable adjustable option with adjustable end links - Stuart at AP found a set that are custom made and very very expensive - so I passed
Old Nov 9, 2016 | 04:28 AM
  #35
Montana107's Avatar
Below is a photo of the wear I got on the top of my fender liner:
Old Nov 9, 2016 | 03:33 PM
  #36
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
Bilstein shocks with Eibach springs. I believe the shocks are custom made for AMR, thus the super high price.
Feb 24, 2016 01:10 PM
midtownlandman
Sep 3, 2015 01:17 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
