left front turn signal
Old Feb 22, 2025 | 07:17 PM
  #76
OjaiM5's Avatar
5 Year Member
OjaiM5 has a spectacular aura aboutOjaiM5 has a spectacular aura aboutOjaiM5 has a spectacular aura about
Wolfgang - You can throw it in complete but keep on eye on the temp. The lowest my oven would go was 180 and it took less than 5 minutes. Be carful prying the tabs, try and get two popped off at a time with two pry tools or flatheads. My lens came off easily. Good luck!
Old Feb 23, 2025 | 07:58 AM
  #77
Wolfgang5150's Avatar
Wolfgang5150
Thanks! We’re cooking today! Low and slow….
Old Feb 23, 2025 | 04:04 PM
  #78
Wolfgang5150
Welp - it worked! 240 degrees for 20 minutes…was scary - drank a glass of wine to ease my nerves - but got it open…so far this is a doable job….thanks for all the advice!
Old Feb 24, 2025 | 01:43 PM
  #79
Wolfgang5150
So per my tech, my board is toasted not sure if it was condensation or what …it’s basically breaking apart as he tests the solders etc - any thoughts and where to source a new board?
Old Mar 9, 2025 | 03:57 PM
  #80
Wolfgang5150
Further ongoing update, headlight out circuit board taken out and to a computer repair shop a bunch of the capacitors were falling off. They went through replaced a few re-soldered them on other loose ones as well …really did a thorough job plugged it back into test it and it still doesn’t work so I guess I’ll just keep picking away at this …
And drinking
Old Mar 10, 2025 | 02:26 PM
  #81
OjaiM5's Avatar
5 Year Member
Well Somewhat similar story. My board came back from the computer repair shop last week. I had provided the tech with all the part numbers and locations for the capacitors. I Plugged it in and the thing went up in smoke. The tech had not paid attention to the locations of the specific parts. It is back being "repaired". So frustrating - I will take a drink as well.
Old Mar 10, 2025 | 03:21 PM
  #82
Wolfgang5150
Ugh sorry to hear that. I actually took mine back to the place just to have them check the capacitors. I’m wondering if they just re-soldered them without actually checking them
Old Mar 10, 2025 | 06:13 PM
  #83
TonyN923's Avatar
TonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the rough
Too bad we don't have a source in the US that can do this as a business
Old Mar 10, 2025 | 10:50 PM
  #84
J doubleU's Avatar
Has anyone tried an alternative LED array to replace the OEM board? Wondering if it would cancel the warning message if LED strips are fitted.
Old Mar 11, 2025 | 10:52 AM
  #85
Wolfgang5150
I found this company in Houston: he offers it,
but he’s only done a few Aston’s….one had issues but it seems to work
Either way this problem won’t be going away as cars age…
https://www.code114llc.com
Old Apr 27, 2025 | 01:37 PM
  #86
OjaiM5's Avatar
5 Year Member
I got my board fix and it worked for one day and went back to throwing the warning code and not working. Pretty frustrating.
For now I am thinking about running wiring from the side indicator to the front bumper indicator and adding a bulb for turning up there. I don't like that other drivers don't know I am gong to make a left.
Does this sound like a good temp fix?
Old Nov 4, 2025 | 07:51 AM
  #87
Mehdi89's Avatar
Mehdi89
Other reference
Originally Posted by OjaiM5
Well I got my board out. I am going to see if Gadget Guys can test it / fix it.
Here is a parts list of capacitors for future reference for anyone
This is for 102
https://www.digikey.com/en/products/...Y3IHIBEQBdAXyA
This is for 221
https://www.digikey.com/en/products/...ByAIiALoC%2BQA
This is for 33 2AFK
https://www.digikey.com/en/products/...luQOQBEQBdAXyA
and I believe this is for 220 HFK (might want to double check this)
https://www.digikey.com/en/products/...w4oME4cyBgTcKA
hello.
Thank you for your help.
Do you have an other référence or url for the 220 capacitor ?
Old Nov 6, 2025 | 07:13 AM
  #88
OjaiM5's Avatar
5 Year Member
I was under the impression that the above capacitors were correct. Saying is however, my repair did not last. Maybe someone with more knowledge can chime in?
Old Nov 7, 2025 | 03:49 PM
  #89
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Does anyone know where to get a new board without going to AM?
Old Nov 7, 2025 | 03:56 PM
  #90
handyman2009's Avatar
Veteran: Canadian Forces
You could try these guys.
https://controlrepair.com/shop/philips-electronic-instr-21054-signal-circuit-board-119037#attr=852436
