navigation question
Old Sep 28, 2015 | 08:13 AM
embdenb's Avatar
navigation question
2007 vantage V8 the navigation screen does not rotate all the way to vertical, it stops somewhat short of being completely “up” Is this normal?
The first to second shift is hard until the gearbox warms up. I had read somewhere that Aston Martin recommends an oil change of the gearbox, using a new type of oil, to cure this problem.
Has anyone had this done? What type of oil was used? Do you have to get this done at the dealer?
Old Sep 29, 2015 | 08:24 AM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Has anyone had this done? What type of oil was used? Do you have to get this done at the dealer? Thanks
You need the navigation gearwheel repairset. It's a common issue on older cars: the gearwheels get brittle over time and this i.c.w. wrongly used grease results in fast ageing gears. You can buy it here http://astonmartinbits.com/models/5-...tage/parts/676 and it's a fairly-easy DIY to tackle yourself
Old Sep 29, 2015 | 11:04 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
While you may indeed have a problem with the nav display, it does NOT go completely vertical even when working properly. You should be able to find some photos online.
Old Sep 30, 2015 | 08:04 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Transaxle fluid change details here:
https://www.6speedonline.com/forums/...id-change.html
I recommend using the Castrol BOT 270A fluid-it's a dealer purchase item.
Old Sep 30, 2015 | 08:16 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
There was also a update to the bell crank on top of the transmission. This with the fluid change will help.
Old Sep 30, 2015 | 09:27 AM
embdenb's Avatar
Smile
Thanks for all the prompt replies. I appreciate it
cnebrask
Oct 3, 2024 08:19 PM
RallyBird
Oct 7, 2015 01:20 PM
spreeon
Aug 27, 2015 08:14 PM
