Door handle LED replacement
Old Oct 6, 2015 | 06:30 PM
00aston's Avatar
00aston is infamous around these parts
With the vantage in for Gbox oil service, I had the dealership look into replacing the door handle LED on the drivers side as it no longer works. A relatively simple fix one would assume but apparently it requires replacing the entire inner mechanism of the handle.
Anyone fixed this issue without spending £250 plus labour that they are asking for. Surely a small LED can be replaced without replacing the entire unit
Old Oct 6, 2015 | 07:16 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
I just pulled out door handle on my DB9
I guess it should be similar
You will have to remove door panel trim from inside
Remove the widow glass just to reach the three nuts holding the handle
It's lot of work to just reach the handle unit but DYI IS POSSIBLE BUT YOU WILL HAVE TO GET THE ASSEMBLY as it looks like led is part of that assembly , if you find the old one may be you can swap it.
Risley
Sep 19, 2015 01:22 PM
The_Orange
Sep 15, 2015 08:11 AM
AlecS
Sep 12, 2015 10:51 AM
Nikg
Sep 11, 2015 01:56 PM
ECS Tuning - VW
Sep 8, 2015 01:34 PM
