Bumpers upgrade
Old Apr 9, 2020 | 05:09 AM
  #91
handyman2009's Avatar
Veteran: Canadian Forces
Nice work, now what wheels are you going to be running?
Old Apr 9, 2020 | 06:05 AM
  #92
bunob's Avatar
bunob is infamous around these parts
Aston Martin GT12, 7-spoke magesium centre locking wheel in satin biack.
Front 7,6 kg / Rear 8,4 kg
Old Apr 9, 2020 | 06:09 AM
  #93
Wow that is impressive, it will be one awesome build for sure.
Old Apr 9, 2020 | 06:13 AM
  #94
bunob's Avatar
Thanks ;-)
Old Apr 9, 2020 | 10:24 AM
  #95
skeena river rove's Avatar
skeena river rove is infamous around these parts
I love it! Where did you get those wheels? impressive work!
Old Apr 9, 2020 | 01:29 PM
  #96
MRCW's Avatar
Originally Posted by bunob
Thanks ;-)
with that kind of weight reduction, I just need to lose my father-in-law in the passenger seat!
your way is easier!
Old Apr 10, 2020 | 01:07 AM
  #97
bunob's Avatar
For the Brake Caliper Stud conversion :
Aston Martin recommends replacing the bolts each time the brake calipers are removed. Now this is no longer necessary.
The factory bolts will quickly strip out the threads in the wheel knuckle, when removing the calipers for maintenance (pad replacement on CCM brake for example) .
These caliper studs will eliminate this problem. They also allow for quicker and easier caliper installation by guiding the calipers into position.
I find them at TARETT Egineering and they are designed for PORSCHE https://www.tarett.com/items/986-987...csk-detail.htm
Old Jun 17, 2020 | 08:56 AM
  #98
Matt Barnes's Avatar
Matt Barnes is infamous around these parts
Bruno, do you know the cost of the centre lock conversion and those mag wheels?
Also, what is it about the knuckles / suspension uprights that means you need to change them to fit 6 pots? I cannot work out what is different about them to the 4 pot uprights
Old Jun 17, 2020 | 11:06 AM
  #99
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
The 6-Pots have a wider spacing in the caliper for the bolts, hence the (expensive) necessity for new knuckles.
Old Jun 17, 2020 | 12:32 PM
  #100
thanks. I’m trying to plan a brake upgrade on the front and having to add new knuckles and bearings makes the oe 6 pot route very expensive.
out of interest Bruno do you know the weight of the vantage 6 pot caliper?
Old Jun 19, 2020 | 04:48 PM
  #101
SLVRon's Avatar
5 Year Member
SLVRon is infamous around these parts
Just fitted onto my V8 Vantage :
- a Nitron NT R1 Suspension kit.
Great thread! How do you like the Nitron NT R1 suspension compared to the stock setup? I hear mixed things about Nitron - though most of the negatives are related to long term maintenance.
Old Jun 21, 2020 | 02:19 AM
  #102
bunob's Avatar
The center lock conversion was a priceless challenge.
I was very lucky to find used GT12 used wheels. A single brand new wheel costs more than £ 6,000.
For the CCM disc I take the Vanquish ones because the Aston center lock system have the same center bore and PCD than the Vanquish not the same than the V12 Vantage one.
The front and rear Vanquish calipers are the same than the V12 Vantage one (but different than the V8 Vantage S).
At first I try to use the V8 Vantage S whith the CCM discs but they don't match...
Old Jun 21, 2020 | 02:23 AM
  #103
bunob's Avatar
The Nitron NT R1 are 7.11 kg lighter than OEM ones and they seem to be of very good quality.
They're comfortable enough although harder.
Old Jun 25, 2020 | 07:15 AM
  #104
Did you go for the 95mm equivalent kit?
Old Jun 25, 2020 | 07:16 AM
  #105
hmm, $93 dollars for shipping. maybe not!
