Clear Bra
Old Oct 27, 2015 | 07:55 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I was told after doing my full front not to hit it directly with high-powered spray and to make sure bird droppings were washed off as well as bug splatters relatively timely
Old Oct 28, 2015 | 08:23 PM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
A couple of us in the Atlanta area have a guy that does awesome custom work for the Aston.
I did a full paint correction, clear wrap, and Modesta coating, and would do it all over again in a heartbeat.
Best decision I ever made!
Message me if you'd like the contact...
Old Oct 28, 2015 | 08:40 PM
Prefurbia's Avatar
No best decision you ever made was buying the Aston- maybe 2nd best was bra
Old Oct 30, 2015 | 02:16 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
XPEL is a fantastic clear bra, yes it's pricier but it's the best. I would avoid 3M clear bras bc they have way too much orange peel.
Old Oct 30, 2015 | 02:43 PM
mindscape9's Avatar
mindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to allmindscape9 is a name known to all
With Batman 100%. He is one of the best around. He uses Suntek rather than Xpel because he feels its easier to work with when doing a custom install. Was able to do my entire car and there isn't a seam showing anywhere. Really amazing what a talented pro can do.
Old Oct 30, 2015 | 03:38 PM
XJRS Owner's Avatar
Maybe a few years ago, but not anymore. The latest 3M stuff is clear as glass.
Old Nov 1, 2015 | 04:47 AM
Montana107's Avatar
Montana107 is infamous around these parts
PM sent Batman! Thanks for the help! I will have one soon! I have been wanting to do this but wanted the person doing the job to have some Aston owner references.
Old Nov 19, 2015 | 02:05 PM
XPEL's Avatar
XPEL is a jewel in the roughXPEL is a jewel in the roughXPEL is a jewel in the rough
Originally Posted by Rusty Heap
to what extent would the clear bra cover/hide existing minor rock hits/chips on a 996 hood?
with no touch up paint
Car has numerous small pits from many years of lovin'
I think small blobs of touch up paint in each pit before clear bra, might even make the chip stand out more?
It wont necessarily hide any of the rock chips, best bet would be to have them professionally fixed first. With just touch up paint, there is the chance that it will appear to have little bumps under the clear bra.
Old Nov 19, 2015 | 02:08 PM
XPEL's Avatar
Originally Posted by scottsilv
If I have a clear bra applied to the front bumper, headlights, rocker panels and lower portion of the hood (or full hood), what do I do for washing, waxing, polishing, etc. After that?
If its XPEL ULTIMATE, you can treat it as you would clear coat. Only warning is to not use anything that contains Petroleum Distillates such as Naphtha/Kerosine as this can compromise the bra and cause pre-mature yellowing. But you can use polishes, waxes(non-dyed), and wash it as normal. A lot of our customers use a waterless wash.
For the hood many people here can tell you full hood, because even while the line is hard to see at certain angles, it gathers dust and dirt over time.
Old Nov 19, 2015 | 02:09 PM
XPEL's Avatar
Originally Posted by Montana107
Any recommendations on the best place to have this done in the southeast?
Thx!
Where about's in the southeast? We have local installers all over the country...click: XPEL LOCATOR for a list of installers
Old Nov 19, 2015 | 02:30 PM
XPEL's Avatar
Regarding the power washer, the areas to avoid are where there is a seam, or where the clear bra ends.
Regarding the bugs and bird droppings it depends on which brand/bra was applied.
XPEL ULTIMATE is self-healing so even if you don't remove the bird droppings/bugs right away it should be okay. With regular paint if you don't remove bugs/bird droppings they can damage the paint and leave a haze/etch in the clear coat. With the self-healing technology of XPEL ULTIMATE once you remove the bird droppings or bugs if there is any hazing/etching, just use our film cleaner, wash and let it sit in the sun to self-heal.
Old Nov 23, 2015 | 11:26 AM
little nellie's Avatar
little nellie is infamous around these parts
I think clear bra is the best investment you can make to protect the finish of your car. Go for a full front coverage as it doesn't show seams at all. In my wife's S550, we did the half coverage and a rock landed a few inches after the bra ends. For my SL and DB9, we have full front done. Most recently, the installer is using a brand called Suntek. It is very smooth and shinny. Matches the shinny AM finish very well. Much better finish than the 3M products that has an orange peel look on the other cars we have.
Robert, the installer tells me Suntek is a self healing film. If I have light scratches, he can fix it by applying some heat to the film. He did that for me and it is just simply amazing.
Most importantly, find someone that has wrap DB9 before and doesn't just use pre-cut film if you want all the edges covered. The person who did the wrap for me in Belmont CA, he even cover the mirrors, door edges and headlights.
KOCF
Jul 18, 2019 03:09 AM
jab23
Cayenne 958
Oct 2, 2015 08:40 AM
poundsan
Oct 2, 2015 12:04 AM
DYL 911
Oct 1, 2015 02:47 PM
embdenb
Sep 24, 2015 10:19 AM
