Driver window not rolling down.
Old Nov 10, 2015 | 05:19 AM
alexhuth's Avatar
alexhuth is infamous around these parts
Hey guys, I have searched the forums but couldn't find this issue. My window won't roll down on the driver side. It worked last week. It doesn't do any motion while opening or closing the door. I wonder should I open the door up and start poking around or should I got to the dealer? Not sure if it matter but I did set off the alarm before I noticed that it wasn't working. 2007 Am v8v Thanks!
Old Nov 11, 2015 | 07:48 AM
alexhuth's Avatar
What no one has had this issue?
Old Nov 11, 2015 | 08:09 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
Did you try windows reset?
Old Nov 11, 2015 | 08:19 AM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
It sounds like his window doesn't move at all, as if he's not getting power to the motor.
Old Nov 11, 2015 | 08:31 AM
alexhuth's Avatar
Yes the window doesn't move at all.
Old Nov 11, 2015 | 09:17 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I had to have my window regulator replaced because window movement started to struggle (and sound nasty). It still did the door open drop, but not much else.
Old Nov 11, 2015 | 06:41 PM
alexhuth's Avatar
Thanks for the suggestions guys.
I was able to fix it pretty quickly tonight. I had to pull the plugs on the door module. So I removed the door cover and found the module, I unplugged the left and right plugs ( I was going to do the bottom one but my baby fingers couldn't get it unplugged). After waiting awhile and plugging the two back in I tested the window and eureka!! It worked. I put the panel back on.
I then did the reset procedure and it now would open and close properly while using the door.
This is where I found the info on resetting the door module.
https://www.6speedonline.com/forums/...er-window.html
spitfun
10
Dec 4, 2015 06:53 AM
SrWilliams
Nov 10, 2015 09:23 AM
gramos
Nov 9, 2015 08:17 PM
Amiricanmade
Detailing
Nov 9, 2015 03:24 PM
Car
New Member Introductions
Nov 9, 2015 12:08 PM
